dang afc pin
dang afc pin
Postby randyswelding » Tue Feb 10, 2009 10:22 pm
does any one know what the od of the afc pin is or where i can find out from.after several atempts to stop my top from leaking by changin the lil green oring out and puttin it back together it willstart leakin after bout 2 weeks,what gives :x am i missin somethin is there another oring that i missed or is this pin too warn.the pin is in great shape no wear marks just a shinny machined surface.has this happened to any one else?hey bgilbert and tim still leakin eaven after scheids and after i got home and fixed it :lol: thanks guys
'92 D350 cab and chassy,pump turned up with 1/8 timin,coaltriann 6x16 sticks,htt manifold,asa intake cooler tubez,south bend 13" clutch rebuilt G360,ps cooler,industrial super 62 phat shaft turbo,weldin bed.
12 Chevy 3500ltz lifted, deleted, and bed with sae 300 ss hood for new rig
randyswelding
Postby CumminsPride » Tue Feb 10, 2009 11:15 pm
Randy, why don't you swap the pump tops from your spare motor and put the afc arm back in it. That one never leaked! Good luck on the seal though.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby randyswelding » Wed Feb 11, 2009 6:39 am
Ya that's what I'm goin to do most likely tonight after work.wade I already got the pump and head off and that motor still has a nice cross hatch. But wha( I wqould like0 ta0know is why its doin this
randyswelding
Postby KTA » Wed Feb 11, 2009 3:14 pm
Do you have a ground or aftermarket control pin?
Postby randyswelding » Wed Feb 11, 2009 6:37 pm
Both a grounded one that isn't ground too bad still has a lot of meat on it, and a ddp pin also
randyswelding
Postby KTA » Wed Feb 11, 2009 10:09 pm
It doesn't take too much grinding on the deep side of a stock pin to be too much and to cause a leak by allowing the pin to travel too far. I have seen this with several aftermarket pins as well. Not all pumps are made the same and a couple thousandths here and there can add up to trouble with one and none with another. I would recommend turning your cone to the shallow unground side for a bit and see if your leak quits. It is the cheapest fix you can get if it works.
Postby randyswelding » Thu Feb 12, 2009 12:01 pm
The grounded pin is barley grounded not like the last one which was almost cut off the pin its self.I put the other top on last night with no afc and no leak what I'm goin to try and do is take every thing apart and reseal the top and turn the factory pin to stock and see how it does.why does it leak with only a lill grinding,when I check how much pin should be stickin out of the allen head
randyswelding
Postby bgilbert » Thu Feb 12, 2009 1:25 pm
Must be operator/installer error :lol: !
Bill Gilbert
bgilbert
Postby CumminsPride » Thu Feb 12, 2009 1:35 pm
How did the truck run without the AFC? LOL
CumminsPride
Postby randyswelding » Thu Feb 12, 2009 4:34 pm
Dang good not as smokey as I thought and no hesatation on boost like before
randyswelding
Postby CumminsPride » Fri Feb 13, 2009 5:55 am
It's really a night and day difference.
CumminsPride
Postby randyswelding » Fri Feb 13, 2009 8:36 pm
No the night and day is when you reinstal the shut off plunger and it won't shut off the truck but cut off over half the fuel when 1 clip comes off.so I redid the clips and now all good
randyswelding
Users browsing this forum: No registered users and 78 guests
