B 1-2 Turbo Question
Postby 90FIRSTGEN CUMMINS » Sun Sep 13, 2009 10:33 am
Ok I found a good deal on a B 1-2. It needs a wastegate actuator. Ive been looking and it seems like it has a different size exhaust flange on it. It measures 4 and 5/8 to the outside. It also has some shaft play but i will have it rebuilt. The reason I am asking about about the exhaust flage is I dont think it is the same as a hx 40 and not sure what to ask for when I need a flage to make my twins. KTA you might have the same thing on your b1 but Im not sure.
1990 W250 Non I/C, Mostly stock,4 inch Ex,Fuel Screw Turned Up a Little, 727TF, 366 spring, BHAF, Borgeson Steering Shaft, Under-bed B & M transmission cooler, head lights now on relays(just added)
90FIRSTGEN CUMMINS
Postby TTipswprd » Sun Sep 13, 2009 11:13 am
I Believe the T-3 Is the stock flange.
TTipswprd
Postby 90FIRSTGEN CUMMINS » Mon Sep 14, 2009 12:08 am
Yeah the manifold side is a t3 but I am talking about the vband side.
90FIRSTGEN CUMMINS
Postby 90FIRSTGEN CUMMINS » Mon Sep 14, 2009 12:12 am
90FIRSTGEN CUMMINS
Postby okish » Mon Sep 14, 2009 12:36 pm
sounds like a standard 4 inch full marmon to me.
89 D250- G360, Bombed VE, BHAF, 4 inch turbo back, 60mm h1e/h1c hybrid, 16cm3 pdr ported housing, custom 2.5 inch crossover pipe, denny t stg 2 fuel pin, piston lift pump.
okish
Postby 90FIRSTGEN CUMMINS » Tue Sep 15, 2009 7:06 am
Ok I checked with source auto and they dont have any adapter flanges for a marmon. Anyone out there have any suggestions where to look for flanges for this style flange. Thanks Jason
90FIRSTGEN CUMMINS
Postby SOOT4BRAINS » Tue Sep 15, 2009 9:54 am
Call Gillett Diesel, they may have it. They have a good price on their flanges as well. Just got a 4 inch vband flange and clamp from them for $15 for my friends s300 install.
93 D250 Rag 3.54, 4 inch stans downpipe to custom 4 in exhaust, pump cranked with m3 pin, 366 spring, tach,boost,pyro,fuel pressure, ddp 70lpm sticks, 62/65/12 s300, airdog 150, rebuilt getrag, 3250 SBC clutch, helix 2 camshaft, dual redtops, new paint.
SOOT4BRAINS
Postby 90FIRSTGEN CUMMINS » Tue Sep 15, 2009 11:28 am
Will do. I would like to just get a flange that goes from what i have to a hx40 vb flange so If I buy a hot pipe for my twins I can just get a s300 to and s400 and later on if I get ride of this turbo and get a s300 I can still use the pipe. Thanks Jason
90FIRSTGEN CUMMINS
Users browsing this forum: No registered users and 89 guests
