New fuel system
New fuel system
Postby Oddfire » Mon Nov 23, 2009 8:02 pm
I am building a 1/2" system and need to get some ideas on the fitting into the pump. Could any one post a photo of what they did? :lol:
Thanks ;)
Oddfire
Postby ahale2772 » Mon Nov 23, 2009 8:11 pm
which pump? piston or stock
Postby Oddfire » Mon Nov 23, 2009 9:52 pm
I/P....... :lol:
Oddfire
Postby SOOT4BRAINS » Mon Nov 23, 2009 10:01 pm
I got a 12mm x 1.5mm to 8 JIC adapter from Vulcan, used a 8 JIC 90 degree cast elbow and I drilled the side of it for 1/8 pipe thread for my fuel pressure gauge. Works great.
Had to modify part of the throttle to get it top fit.
It clears everthing else fine. I also got a viton sealing washer for the fitting that screws into the pump. It has never leaked a drop.
Do not get the pre drilled 90 degree piece from vulcan, it has the wrong side drilled for this application, it is drilled so the gauge line points up, not to the side. Ran it from there to a gauge isolator.
93 D250 Rag 3.54, 4 inch stans downpipe to custom 4 in exhaust, pump cranked with m3 pin, 366 spring, tach,boost,pyro,fuel pressure, ddp 70lpm sticks, 62/65/12 s300, airdog 150, rebuilt getrag, 3250 SBC clutch, helix 2 camshaft, dual redtops, new paint.
SOOT4BRAINS
Postby Oddfire » Mon Nov 23, 2009 11:23 pm
Which fitting on vulcan's web site is it? I cant seem to locate it. :roll:
Oddfire
Postby IowaCummins » Tue Nov 24, 2009 4:16 pm
this might help y awith sizes and what not. http://www.dieseltruckresource.com/dev/ ... l?t=151190
IowaCummins
Here ya go
Postby ZSkibo » Wed Nov 25, 2009 2:42 pm
This is the regulator that I used:
Mallory 4307M - Mallory Universal Fuel Pressure Regulators for Fuel Injection - Overview - SummitRacing.com
I'd say it's not an issue if it's rated for gasoline/alky. Also, here is a list of everything I ordered from Vulcan (quantity first, rice second). Note, this does not include the pump, the fuel hose, clamps, and a few other little odds and ends I used but you get the idea and see what fittings are needed to tie into the fuel system.
M1406 14mm metric to 08 MJIC adapter 1 7.49
FFVPU Filter to injection hose kit 1 33.99
DSI DrawStraw I 1 44.99
M1208 12mm metric to 08 MJIC adapter 1 6.89
PO168 Pushlock 1/2 x 06 JIC swivel 1 5.99
po188 08 jic swv x 1/2 PL 2 2.49
PLG06 Pipe plug 3/8 NPT 1 1.19
240468 3/8 NPT x 08 MJIC adapter 1 1.59
650066 Forged 90 deg 06 FJIC x 06 MJIC 1 2.29
POE Pushlock 1/2 X 08 FJIC 90 Deg 2 6.59
Finally, a link to the pics:
http://www.cumminsforum.com/forum/89-93 ... nally.html
92 W250 Pump bombed, AFC out, 366 spring, 18* timing, KSB hotwired, HX35 12cm non wg, New Era 6x18's, BHAF, 60 lb in/ex springs, 4" PAC Brake, onboard air, Nathan P3 horns
ZSkibo
Postby smilesyota » Wed Nov 25, 2009 6:27 pm
just upgraded to a low pressure lift pump and big filters and 6an line to the pump ang a 366 spring WOW! this thing moves now got all my hose fittings from discount hydraulic hose.com out of PA, they are awesome to deal with great price! fast shipping.
http://rides.webshots.com/photo/2310796 ... host=rides
this is a water seperator and a 2 micron secondary fuel filter.
I'm runnung used ATF and WMO mix. almost a thousand miles with no issues. Filter heads are from fleetgaurd.
smilesyota
Postby Ace » Thu Nov 26, 2009 9:59 am
Ah yeeees. Now that's one way to install a seriously high capacity/high efficiency fuel system! :grin:
Ace
Postby Cummins Junkie » Thu Nov 26, 2009 1:45 pm
I did this upgrade on my truck, i just ordered the big line kit for the 24 valve from vulcan.
1991.5 W250 NV4500 Swap, Ats Manifold, Dual 5" Stacks, Autometer Gauges,P-Pump Swap, KDP Beat Into Submission, 4k GSK, 0 Plate, 191 DVs, P/S Intercooler, 3" Stainless Cooler Tubez, BHAF, Super Hx40, 370s
Cummins Junkie
