3200 SPRING QUESTIONS
Postby FASTRTHNU2 » Thu Nov 26, 2009 10:04 am
I WAS THINKING ABOUT PUTTING A 3200 SPRING IN AND CALLED SCHIED THEY TOLD ME THAT IF I DID THAT IT WOULD CAUSE THE PUMP TO BE UNBALANCED AT HIGHER RPM AND THEN TRIED TO SELL ME A COMPLETLY NEW 14MM PUMP SO WHAT IS THE DEAL I KNOW U GUYS HAVE ALL DONE THIS WHAT KIND OF ILL AFFECTS HAVE YOU GUYS ENCOUNTERD AND HOW MANY MILES DO YOU HAVE ON YOURS
93 W250 ALL STOCK LOOKING AT 5" MITRE CUT STACKS,PHANTOM GAGUES,BIGGER TIRES, AND ANY THING ELSE I CAN FIND
FASTRTHNU2
Postby Ace » Thu Nov 26, 2009 10:09 am
Get the name of the person you spoke with.
Ace
Postby BC847 » Thu Nov 26, 2009 10:09 am
That's the first I've heard that the 3200 spring would cause problems. In fact, I've modified my 3200 spring (clipped a few loops out) and have full fueling to 3600rpm.
And while I have the utmost in respect for the good folks at Schied, I don't know that they spend a lot of R&D on the little VEs. :?
Postby Jfriedlin » Thu Nov 26, 2009 12:36 pm
That sounds like horse S@#% to me. I think the 3200 spring is one of the best $16.95 I've spent on my truck. I've had it in for six months or more with no problems, just a better running engine
Jfriedlin
Postby Cummins Junkie » Thu Nov 26, 2009 1:47 pm
had mine in for almost a year with no problems
1991.5 W250 NV4500 Swap, Ats Manifold, Dual 5" Stacks, Autometer Gauges,P-Pump Swap, KDP Beat Into Submission, 4k GSK, 0 Plate, 191 DVs, P/S Intercooler, 3" Stainless Cooler Tubez, BHAF, Super Hx40, 370s
Cummins Junkie
Postby PToombs » Thu Nov 26, 2009 4:43 pm
The only problem I had with mine is my fuel mileage went way down. I'm not positive, but I think it's because it's more fun to drive with my foot in it. ;)
Postby Jfriedlin » Fri Nov 27, 2009 8:40 am
My EGT's and some of the smoke actually decreased when I put mine in but it is actually a little faster then it was. My fuel mileage is awesome too if i keep my foot out of it
Jfriedlin
Postby Mark Nixon » Fri Nov 27, 2009 9:36 am
I don't know the benfits or drawbacks of the spring upgrade, but I have played with the full power screw and the fuel pin and starwheel adjustment in the past.
All were a bit of improvement, but the governor spring and a tighter turbo housing are purported to be the best gains, if done within reason.
A reasonable bump of pump timing supposedly doesn't hurt, either.
Postby seeker1056 » Fri Nov 27, 2009 11:30 am
man sumbuddy be jerkin yur chain
Even at 46-4700 rpm there were no unbalance issues in my pump
The 3200 rpm spring is the best bang for the buck out there
Git er done
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby FASTRTHNU2 » Fri Nov 27, 2009 6:30 pm
WOW THANKS FOR ALL THE REPLIES I THINK I WILL ORDER THE SRING. I HADNT HEARD ANYTHING NEGITIVE ABOUT IT UNTILL I CALLED THEM BUT I THINK HE WAS TRYING HARDER TO SELL ME THE PUMP GUESS THEY DONT MAKE AS MUCH MONEY ON A 16 DOLLAR SPRING
FASTRTHNU2
Postby PToombs » Fri Nov 27, 2009 6:37 pm
You should be able to get it at any Bosch authorized fuel shop.
And please quit using all capitals, it hurts. ;)
Postby 1STGENFARMBOY » Fri Nov 27, 2009 6:40 pm
Welcome: get you some gauges first thing trust me, once you get your EGT gauge in pull it in the barn and turn up the pump, :wrench: on your test drive you'll swear it ain't your truck, :shock: be careful turnin up the power screw things can go south FAST :pale: , be shure read how to do it in here, :study: :salut: ps the spring is a good upgrade ;)
Postby MMeier » Fri Nov 27, 2009 7:40 pm
Wheres the link with the spring install... can't seem to find it !!!! :roll:
'93 W250CC, 5 speed, 3.54's, pump tweaks, NV4500 conversion, straight piped, 33's. Also, have '03 3500 QC 4WD dually, 551HP/ 1008 TQ @ MATS '07
MMeier
Postby peobryant » Fri Nov 27, 2009 9:44 pm
MMeier wrote:Wheres the link with the spring install... can't seem to find it !!!! :roll:
http://dens-site.net/Dodge_CTD/Governor ... index.html
This is the best one I know of.
Postby MMeier » Fri Nov 27, 2009 11:24 pm
Thats the one I was thinking of ! Thanks !! Now where is this leaking O Ring of mine located... on top, or inside the top cover ?
MMeier
