14mm rotor and 4mm camplate
Postby dazedandconfused » Mon Oct 11, 2010 5:14 pm
Is anyone running them with success? Only articles I found were from 08.
Re: 14mm rotor and 4mm camplate
Postby peobryant » Mon Oct 11, 2010 6:21 pm
dazedandconfused wrote:Is anyone running them with success? Only articles I found were from 08.
In competition only vehicles, yes. In daily drivers, not so much...
Postby dazedandconfused » Mon Oct 11, 2010 6:44 pm
Gotcha. I'm building a 2wd puller so road use is not an issue.
Postby ahale2772 » Tue Oct 12, 2010 5:00 am
ive heard its kindof a tossup if the rotor will live with the big camplate
Postby dazedandconfused » Tue Oct 12, 2010 5:33 am
Anybody on here running one with success?
Postby ahale2772 » Tue Oct 12, 2010 7:10 am
JQmile tried...
Postby JQmile » Tue Oct 12, 2010 9:54 pm
I think it would work if you didn't take it past 3,500rpm....or maybe even 3,000 rpm.....
However, mine was tested at 4,000rpm a few times, and then it no workie :D Too bad you need rpm for sled pullers.
It put out 440cc, which was pretty darn good, but my current pump with a regular camplate puts out 370cc, which isn't bad either.
JQmile
Postby lectro_static » Tue Oct 12, 2010 10:13 pm
I read somewhere that you can use the 14mm head with a smaller cam plate and it will live. Any truth to that and would it make a big enough difference to warrant the expense?
weeping head gasket
4" straight pipe
M&H M3 fuel pin
M&H Dynamic Timing Advance
366 spring
Auto Meter EGT and Boost
lectro_static
Postby peobryant » Wed Oct 13, 2010 6:07 am
Wasn't there a guy with a Ford puller that had a 14mm VE in it? Or did he switch to a P7100? I can't remember his username...
Postby AHineman » Wed Oct 13, 2010 8:12 am
Seeker had a Giles built pump but I think he sold it. Don't remember what cam plate though...
Postby JQmile » Wed Oct 13, 2010 11:23 pm
lectro_static wrote:I read somewhere that you can use the 14mm head with a smaller cam plate and it will live. Any truth to that and would it make a big enough difference to warrant the expense?
Uh...yes? I have a 14mm that has a few thousands street, daily driver, and dyno miles on it, and it's still fine. And with 370cc at 2,500rpm, 600-700rwhp should be attainable, so yep, I would say it was worth it! :mrgreen:
JQmile
Postby dazedandconfused » Sun Oct 17, 2010 7:17 pm
Well I have a few pumps now so may have to have one built with a 4mm camplate and 14mm head. I don't see me carrying more then 3500-3700 rpms if I'm lucky.
Postby KTA » Sun Oct 17, 2010 7:46 pm
[quote="JQmile] Uh...yes? I have a 14mm that has a few thousands street, daily driver, and dyno miles on it, and it's still fine. And with 370cc at 2,500rpm, 600-700rwhp should be attainable, so yep, I would say it was worth it! :mrgreen:[/quote]
Then why again are you only makeing about 500? :lol: Needs more NOS. ;)
Postby JQmile » Mon Oct 18, 2010 7:08 pm
KTA wrote:Then why again are you only making about 500? :lol: Needs more NOS. ;)
It does!! I'm adding another stage. Also adding a lock up trans and 10 deg of timing :mrgreen:
Hopefully those two things will fix my 20% converter slip and big ol flame out the exhaust problems. After that I may finally add an intercooler :D
JQmile
Postby oldestof11 » Mon Oct 18, 2010 8:07 pm
Jason, you adding an intercooler is like Richie adding a 366 FOR THE FIRST TIME EVER, it aint gonna happen.
