2nd gen air horn
2nd gen air horn
Postby lazyjoe » Tue Dec 28, 2010 7:59 pm
What have you guys done on your cooler tube, when installing a 2nd gen air horn? As far as shorting? And where is the best place to buy new intercooler boots?
Joe
93, W350, auto, DTT convertor, 4.10's, GDS 60mm with 14cm, piston l/p, 2nd gen air horn. 366 spring. boost, and pyro.
91, W250, 360 gas, auto, 4.10
95, 2500, 4/4, 5" turbo back. So far.
lazyjoe
Re: 2nd gen air horn
Postby 1STGENFARMBOY » Tue Dec 28, 2010 8:56 pm
frozen boost sells the boots
Postby PRINCETON_JAKE » Tue Dec 28, 2010 10:55 pm
I built my own "cool tubes" i bought a 3" diameter 45 degree mandrel bent aluminized exhaust pipe from the parts store, it was like $20 at the parts store, then but welded a 2.5" reducer on the intercooler end, then bought 6" of 3" diameter heavy duty radiator hose (its multi ply not like a curved hose) I bought 2 new 3.5" diameter clamps for the top connection, and re used the stock lower boot and clamps. In all it was under $40
1992 cummins, 2wd, A518, WH1c, 60mm,12cm housing, fuel screws maxxed, fuel pin turned and ground, 3200rpm spring, big Amsoil air filter, 4" stack, timming bumped, piston lift pump, Bosch 190's, 18" Maxxi Hulk rims, and Nitto Terra Grapplers.
PRINCETON_JAKE
