Give me a 14mm, 'till I'm dead.
Re: Give me a 14mm, 'till I'm dead.
Postby oldestof11 » Sun Apr 10, 2011 12:34 pm
It was said that a 4mm camplate ever so slightly opens the spill over port. Now stock is a 2.8mm lift. Why not try a 3.2, 3.5, 3.7mm lift and see where it goes???
Postby SNOOT » Sun Apr 10, 2011 5:32 pm
I will be pulling my pump and having it all set up and dialed in on a machine along with Denny T AFC delete and 14MM head. Injectors are coming out for a once over as well because I have at least two that leak a little.
I see no reason why I shouldn't be in the 550HP + range or more after all of this work.
1993 W350
SNOOT
Postby KTA » Sun Apr 10, 2011 6:55 pm
Better get those ddp's flowed a bunch more or the 14 will probably bite the big one.
Postby SNOOT » Sun Apr 10, 2011 9:37 pm
KTA wrote:Better get those ddp's flowed a bunch more or the 14 will probably bite the big one.
Thats it thats all I have to do get them flowed?.... Is that all or should I change my cam or my transmission or maybe my stock rear end. What else should I change up?
1993 W350
SNOOT
Postby Richie O » Sun Apr 10, 2011 9:40 pm
I think he means your ddp's won't flow enough fuel which will stress the 14 and sieze it up. You need some big boys to keep a 14 happy.
Postby SNOOT » Sun Apr 10, 2011 9:43 pm
You too..... lol O Richie you disappoint me...
1993 W350
SNOOT
Postby soggy » Sun Apr 10, 2011 10:23 pm
I think you will be disappointed with no AFC and a 14mm.
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby KTA » Sun Apr 10, 2011 10:33 pm
"Flowed" is the term DDP uses for their extrude hone process they then give some kind of Lpm number for each size. DDP 4's are not all that big of an injector for a VE. I am fairly certain the cam and rear end don't have much to do with keeping the pump functional. :roll:
Postby SNOOT » Sun Apr 10, 2011 10:37 pm
I understand what you are saying and have read all of your post in regards to injector sizes.... :) How is the traction with the D350?
1993 W350
SNOOT
Postby ahale2772 » Mon Apr 11, 2011 4:54 am
SNOOT, do you have a base line for power? I know it says your dyno #'s in your sig for the single but what about the twins?...would be nice to see a before and after 8)
Postby SNOOT » Mon Apr 11, 2011 6:19 am
I will have base line HP numbers the way it is now yes..
1993 W350
SNOOT
Postby Richie O » Mon Apr 11, 2011 12:39 pm
SNOOT wrote:You too..... lol O Richie you disappoint me...
I take it there was a joke there somewhere that was way over my head? and still is. :D
Postby SNOOT » Mon Apr 11, 2011 1:24 pm
Let me tell you a little secret... I don't know many out there that share what they are really doing behind closed doors. I love poking fun and keeping people on there feet around here from time to time. Maybe I should install a sneaker NOS system just for fun...
As for the pump I do plan to put it all together and run it on the test stand with and without the Denny T AFC delete. If I dont like it I will have my original AFC unmolested to put back on with the DDP fuel pin... Poke poke...
1993 W350
SNOOT
Postby Tacoclaw » Mon Apr 11, 2011 2:04 pm
I'd guess he was playing dumb and is disappointed that you seem to think he actually was. :?: maybe :?: perhaps :?:
Postby SNOOT » Mon Apr 11, 2011 2:11 pm
I am all full of ears and hold back way more then I know I am truly blessed with all the good information posted on this forum. Thank you KTA, Richie O and Stomp... Do I share well yes if you ever catch me at an event I can talk your ears off but on a forum no I have a real tough time with typing words that can't be twisted all about so it sounds ass backwards from what I was trying to say. I gave up years ago at trying to be serious on the boards.
1993 W350
SNOOT
Users browsing this forum: No registered users and 75 guests
