Swapped ground afc lever for stock afc lever
Postby PToombs » Thu Aug 30, 2007 4:27 pm
Man am I lucky! Mine never tried to run up when I had the screw in more. When I turned it in, as soon as it got a little fluttery, I stopped. Now it smokes so bad, I don't think I need any more! :shock:
Postby 90firstgen » Thu Aug 30, 2007 4:45 pm
dpuckett wrote:Yeah, it is an art form driving in traffic at 17-2200rpm. Took me about a week to get it down smoothly.
DP
Heard that brother! Driving a steady 72mph takes careful concentration! Once I get to abotu 68, it wants to go 85 all by itself. really sucks with no cruise!
1990 2x4, 3/4 ton, Getrag, Cummins N/I
3200 Spring
Full Fuel Screw maxed (+/- 4 turns)
Injector rebuild with bigger nozzles
1/8" Timing bump
Airflo Intake
HTT 56mm Compressor
14cm Wastegated Housing
Stan's 4"
90firstgen
Postby bgilbert » Thu Aug 30, 2007 8:59 pm
You guys need to back out your fuel screws!
The ball end allens were Craftsman: http://www.sears.com/shc/s/p_10153_1260 ... al+Purpose
bgilbert
Postby Begle1 » Thu Aug 30, 2007 9:21 pm
bgilbert wrote:You guys need to back out your fuel screws!
What do you mean by that?
You mean that we need to thread them in farther to the point that we can only see the back edge of the screw?
Postby bgilbert » Thu Aug 30, 2007 9:50 pm
No, so you're not running around with your engine near runaway. No wonder everyone's shutoff solenoid/plunger's are going out lol.
bgilbert
Postby PToombs » Fri Aug 31, 2007 4:40 pm
bgilbert wrote:No, so you're not running around with your engine near runaway. No wonder everyone's shutoff solenoid/plunger's are going out lol.
You talkin' ta me? :shock:
:lol: :lol:
Postby wannadiesel » Fri Aug 31, 2007 6:49 pm
I had mine up there for a little while, but it's really spooky with a stick when you let off the gas and push in the clutch and the RPM doesn't fall. :shock:
Best dyno: 408/844
wannadiesel
diesel guru
Postby bgilbert » Sun Sep 02, 2007 8:14 pm
Greenleaf wrote:My 90 wants to run-off @ 2000 rpm's. However when driving the truck, the load on the engine will not allow such an occurance. It only seems to do it in "N" when I slowly apply throttle.
After a road trip in my 89 I've found it does this exactly. I can cruise at 2k rpm ~65-70mph without the twitchy governor.
Bill Gilbert
bgilbert
Postby GLHS » Sun Mar 16, 2008 9:56 pm
KTA wrote: Also you can remove the pin that rides against the cone and replace it with a longer one to take more advatage of the afc, then replace the fuel pin with a tapered one with even more offset to get even more travel, then it moves just as far as a cut foot but still has AFV control. :) 8)
Brian; This mod will still retain the same peak hp as a ground afc lever?
Drove my truck the last few days like a wuss (except for 35 miles of 87 mph) and was rewarded with 19.7 mpg; highest ever!
Wanted: Stock afc lever. :)
GLHS
Postby KTA » Mon Mar 17, 2008 5:32 am
Yes it will retain the same fueling because it allows the same amount of travel, but still has AFC control. 8)
