propane or hx40 upgrade for towing
Re: propane or hx40 upgrade for towing
Postby dazedandconfused » Wed Feb 22, 2012 6:14 am
Ring&Pinion
Postby U.S MMA » Wed Feb 22, 2012 9:46 am
what size is the exhaust housing on a hx40? you might be allright, my old man used to reguarly gross out at 22-24 with my truck, bone stock, just do about 33mph up the steep, but it would do it. all i know, is ive been battling egt's since i started tinkering with the beast, i have all the parts for a 4inch, just need to put it on, that will help, but as soon as you add enough fuel to move up a hill at a decent clip, egt's get sketchy. get a 3200 spring, that will help a lot.
90w250,5spd,flatbed,dually swap, power lock ,kelderman, fresh trans rebuild, valair stocker,newer 9leaf,2"skyjacker
3200,60wheel65 16 pacbrake,60exhaustsprings,93 head, snowstage3,
custom bumper broken winch,topboxes,underboxes. J&H helped out a lot. slowly restoring(real slowly)
U.S MMA
Postby oldestof11 » Wed Feb 22, 2012 4:44 pm
Slow down there. A S300 is just as cheap and more reliable with the slightly larger shaft.
http://www.himni-racing.com/index.php?m ... bjc6v9flg1
S360 is about the same size, same price, and you don't loose your back-up turbo.
Postby Tacoclaw » Wed Feb 22, 2012 5:07 pm
It says that's got a T4 housing, so he's either buying a new housing or putting an adapter on his manifold.
Postby oldestof11 » Wed Feb 22, 2012 8:59 pm
Still would hold up better than the Super 40 and take much more abuse. The adapter is not much.
Postby Diesel Dawg » Thu Feb 23, 2012 1:36 am
Ive heard a T-4 foot turbo is laggy on the ve???
Diesel Dawg
Postby oldestof11 » Thu Feb 23, 2012 3:18 pm
T4 foots have nothing to do with spool. The A/R raito (area to radius) is what effects spool along with compressor size/design, bearing/bushing type, shaft weight, turbine size/design. Getting the .91 A/R is equivalent to a 13 or 14cm housing. .88 A/R is 12cm but it is undivided so spooling may be affected by the exhaust pulses.
Postby Remps » Thu Feb 23, 2012 11:01 pm
Oldestof11, where are you getting your A/R to cm conversion from? I'm asking because I remember Richie mentioning that he had talked to a borg warner tech once, and he was told .80 ar = about 14 cm, if I remember correctly. That would make a .91 equal to 15 or 16 cm turbine housing. I've also seen T3/T4 adapters on ebay for around 40 bucks, so that really isn't a big deal either. (EDIT)Looked at the specs a little closer, and it looks like that turbo has a 3" v-band outlet.
Postby oldestof11 » Fri Feb 24, 2012 3:11 pm
Maybe that's it. It was a post by Richie I remember... Been a long time.
Users browsing this forum: No registered users and 68 guests
