by Remps » Thu Feb 23, 2012 11:01 pm
Oldestof11, where are you getting your A/R to cm conversion from? I'm asking because I remember Richie mentioning that he had talked to a borg warner tech once, and he was told .80 ar = about 14 cm, if I remember correctly. That would make a .91 equal to 15 or 16 cm turbine housing. I've also seen T3/T4 adapters on ebay for around 40 bucks, so that really isn't a big deal either. (EDIT)Looked at the specs a little closer, and it looks like that turbo has a 3" v-band outlet.
