Fuel pressure question
Re: Fuel pressure question
Postby tampabayBill » Wed Jan 02, 2013 7:54 am
I've run mine for 3 yrs with no leaks or other problems.
Twins coming soon!
tampabayBill
Postby RCCUMMINS89 » Wed Jan 02, 2013 8:13 am
It is not commong for a seal to blow at 15 psi.... it has and does happen though. Keep in mind that the seal is only "rated" at 14 psi, and of course most of our seals have a few hundred thousand miles on them.
However, as a rule fo thumb... one is safe to 15 psi.
P.S. Air dog can send you different springs to chance the psi, if one would like to do that.
Postby cummins12club » Wed Jan 02, 2013 12:47 pm
That I may do BC847 is one of the highest hp 12mm trucks around and gets their w only 12psi so I'd line to set mine at that
cummins12club
Postby RCCUMMINS89 » Wed Jan 02, 2013 3:25 pm
I'm pretty sure BC is the current highest hp 12mm truck. Of course, I might just some day build me some twins..... LOL
Postby cummins12club » Wed Jan 02, 2013 10:05 pm
I have the same turbo set up as he has but no cam headwork and no water meth not to mention he had an aftermarket I intercooler I will be dynoing mine in the next 2-3 weeks hoping for 400
cummins12club
Postby AHineman » Thu Jan 03, 2013 7:04 am
He has a better secondary as well.
Postby cummins12club » Thu Jan 03, 2013 7:46 am
AHineman wrote:He has a better secondary as well.
He has an hx35 as his secondary if I remember correctly
cummins12club
Postby AHineman » Thu Jan 03, 2013 8:11 am
62 mm s300 last he said.
Postby cummins12club » Thu Jan 03, 2013 11:27 am
Ahhh see the last time I looked at his complete set up list was almost a year ago on diesel bombers he has switched since then had he said if its any laggier or if he likes it better?
cummins12club
Postby BC847 » Thu Jan 03, 2013 3:21 pm
I've got to stay ahead of you guys.
There's been a couple of cam swaps as well. :roll:
My air mess to date amounts to:
Thinking air IN - OUT . . .
- True 100% cold air intake.
- Custom BHAF.
- 4" primary feed with ED butterfly shutoff.
- HT3B* primary with a 21 ? cm exhaust housing.
- 3" cold pipe.
- S362* secondary with a waste-gated 14cm exhaust housing.
- 3" IC plumbing
- Custom Hellman IC (stupid 22" x 32" x 3" or there abouts core with 1/2" bar passages. I can't remember).
- TwinRam intake-log feed-horn.
- A fairly decently ported head from PDR
- Steel Hamilton 188/220 cam, his stg1 push-rods, valve-springs, retainers and locks. 24v lifters.
- Cleaned-up ATS 3-piece exhaust manifold*.
- 4" down-pipe to just past the transfer-case where it swells to 5" on out to past the rear axle.
- BHM (there's a 5" Y-pipe just before the BHM for a temporarily installed 5" stack for race-day ;) ).
- All charge-air plumbing is effectively port-matched.
* The turbo-charger, compressor housings are externally coated with a heat-shedding coating.
* The turbo-charger, exhaust housings and exhaust manifold are internally coated with a heat reflective coating to keep heat from transferring to the exhaust housing metal. The exterior is coated with a heat retaining coating to help keep the heat in the housing.
Sitting here, looking at that list . . . . . . . . . :roll:
Postby RCCUMMINS89 » Thu Jan 03, 2013 3:51 pm
Boy... talk about a $10,000 air system, LOL
