cubedeficient64 wrote:I have a set of delivery valves like the long holder set in the first pic, it has an even larger land on it than the ones shown, it also has another small check valve type set up in the end where the fuel line screws on, looks extremely restrictive, I cant find info on why it would be there.
turboram wrote:BC those appear to be vw delivery valves , and yes they are very restrictive. swap for ones without the reaction piston. On the other hand if you remove the shoulder or reaction piston the dv will keep residual pressure in the fuel line thus moving more fuel .
note the cummins ones have a little flat spot on the seat and vw ones do not. The vw engine will not run properly with the cummins dv's , tried it .
BC847 wrote:I've got another split injector tip to deal with. Gonna replace the entire set with something new.
AHineman wrote:BC847 wrote:I've got another split injector tip to deal with. Gonna replace the entire set with something new.
