Do I have a set of NON IC'ed DVs?
Re: Do I have a set of NON IC'ed DVs?
Postby CumminsPower59 » Wed Oct 09, 2013 11:07 am
BC, I checked out the DV's off of my new pump, and they don't have that ridge on them. Another thing is that they have short springs just like the NON-IC's, but have a really long spacer...don't know if this means anything, but somewhere my new pump is lacking and I am trying to fugure out why also...
Postby cubedeficient64 » Fri Oct 11, 2013 5:18 am
I have a set of delivery valves like the long holder set in the first pic, it has an even larger land on it than the ones shown, it also has another small check valve type set up in the end where the fuel line screws on, looks extremely restrictive, I cant find info on why it would be there.
cubedeficient64
Postby BC847 » Fri Oct 11, 2013 5:25 am
cubedeficient64 wrote:I have a set of delivery valves like the long holder set in the first pic, it has an even larger land on it than the ones shown, it also has another small check valve type set up in the end where the fuel line screws on, looks extremely restrictive, I cant find info on why it would be there.
There are a large number of different DVs for different application. Many are modified well beyond that we run, to address different operating conditions. Who knows what you've got. :?
Postby turboram » Sat Oct 12, 2013 1:53 pm
BC those appear to be vw delivery valves , and yes they are very restrictive. swap for ones without the reaction piston. On the other hand if you remove the shoulder or reaction piston the dv will keep residual pressure in the fuel line thus moving more fuel .
note the cummins ones have a little flat spot on the seat and vw ones do not. The vw engine will not run properly with the cummins dv's , tried it .
turboram
Postby BC847 » Sun Oct 13, 2013 7:28 pm
turboram wrote:BC those appear to be vw delivery valves , and yes they are very restrictive. swap for ones without the reaction piston. On the other hand if you remove the shoulder or reaction piston the dv will keep residual pressure in the fuel line thus moving more fuel .
Good info.
Yeah, I'm contemplating just swapping the plunger & seat of my OEM DVs into the longer bodies of the VW looking Dvs. I'm thinking it'll allow the plunger to lift a little further off the seat . . . . because of the difference in the length of the springs.
I'm also toying with the notion of milling the retraction-pistons off those plungers, and running those plungers & seats in the OEM bodies.
Dunno.
I've got another split injector tip to deal with. Gonna replace the entire set with something new.
Thanks guys. :cool:
Postby AHineman » Sun Oct 13, 2013 7:39 pm
BC847 wrote:I've got another split injector tip to deal with. Gonna replace the entire set with something new.
Postby BC847 » Sun Oct 13, 2013 8:24 pm
Perhaps a 5x18 SAC with some extra stuff. Dunno . . .
Postby cubedeficient64 » Thu Oct 17, 2013 12:52 am
Pulled another pump today. Del valve on left is out of the pump I mentioned earlier. Has the long barrel and the extra check valve. Valve on right is out of a non turbo 6bt. Looks a bit less restrictive to me
its also got a flat machined on the seat
[imgImage[/img]
cubedeficient64
