How to remove the AFC lever
Postby bgilbert » Tue Mar 18, 2008 6:31 pm
Why risk it? Little dab will do ya :P .
bgilbert
Postby DTanklage » Wed Mar 19, 2008 12:03 am
kinda like 'more is better' ?
DTanklage
Postby cummins king » Wed Mar 19, 2008 7:30 am
DTanklage wrote:after you swedge them back in they wont leak but you can put what ever you want on them
why put glue on something that isnt gonna fall apart tho?
or sealer on something that doesnt leak?
i dont get it...
just an added percation because if you have and air leak you will lose the prim, and you will lose fuel, its just better to do it once then twic
93 4X4 auto
cummins king
Postby DTanklage » Wed Mar 19, 2008 9:33 am
yea, you are right
i wonder why the factory in germany would put them in dry?
they must be a bunch of dummies
DTanklage
Postby KTA » Wed Mar 19, 2008 10:33 am
Low strength(clear) loctite is used on them stock, or at least thats what the local ADS uses on them to prevent any weeps from developing. RTV or silicone is bad, especially if it gets internal to the pump.
Postby DTanklage » Wed Mar 19, 2008 11:23 am
KTA wrote:
Low strength(clear) loctite is used on them stock, or at least...
when i used to work at the bosch factory we installed them dry
lol
DTanklage
Postby DTanklage » Wed Mar 19, 2008 11:27 am
ps - if you are worried about them leaking do it right
tap em 1/16 pipe and install a plug on either end
dont even have to put the pin back in if you do that
i prefer spilt and toilet paper to hold my balls in tho
DTanklage
