PToombs wrote:Why do you need 12? It's only got 6 cylinders!
fergavs wrote:I had my pump on the stand a few times after having my issues getting the 14mm head and 4mm camplate installed.
On the stand with my 6-18 injectors, 14mm H/R, and 4mm camplate it pushed out a little under 500cc of fuel at 1500 stand rpm. (3000 engine rpm)
On the stand with only the 14mm head and 6-18's it produced over 350cc of fuel at the same 1500 stand rpm.
I figure right now with the 2 stages of gas I should be a ble to break 600hp hopefully. If I can get another 4mm camplate in there and mount the gt4202 sitting in the shop maybe even into the 700's.![]()
Ah well just a pipe dream at the moment. Ill let ya know what happens in the spring with the dyno. If it turns out how I hope then the 1cc per 2hp should be pretty close. KTA's number display that as well.
seeker1056 wrote:rumour has it that the 4mm cam plate and the 14mm head dont like each other lol
Dont think the bugs be all worked out just yet
Users browsing this forum: No registered users and 69 guests
