Injectors
Postby TTipswprd » Wed Oct 21, 2009 9:34 am
it all depends on where you truck is. your gunna get more power from aftermarket sticks from a truck with other power power upgrades than a stock truck.
TTipswprd
Postby Richie O » Wed Oct 21, 2009 2:57 pm
oklahoma6speed wrote:435 is = to what hp.
6x16=?hp
6x18=?hp
435 means 435 horse total. Kinda a guess really. I would agree they could make 435 horsepower if you had the fuel supply and cool air to go with it.
6x16's and 6x18's are basically as big as anyone could ask for. They will support as much power as you can feed them. Most of the big boys run the 6x16 and 6x18's.
Postby seandonato73 » Sat Oct 24, 2009 8:30 pm
hi guys i'm new to this forum.... i have DDP 8ohp injectors in my 90, they didn't really seem to be that much better then stock, where would i get a set of 6x0.018s ???? should i go with a 5 hole injector??? it all confuses me a little :?
90 dodge w250, 4" turbo back exhaust, 80hp ddp injectors, 3200rpm gov spring, fass punp, custom intercooler, injector pump maxed out, reground fuel pin, south bend clutch
seandonato73
Postby burnt_servo » Sun Oct 25, 2009 6:35 am
seandonato73 wrote:hi guys i'm new to this forum.... i have DDP 8ohp injectors in my 90, they didn't really seem to be that much better then stock, where would i get a set of 6x0.018s ???? should i go with a 5 hole injector??? it all confuses me a little :?
after reading your sig , 2 questions come to mind ;
how much pressure is your lift pump feeding into your injection pump ?
what kind of turbo are you running ?
'93 w250 .... stock ...
burnt_servo
Postby Ace » Sun Oct 25, 2009 6:39 am
burnt_servo wrote:how much pressure is your lift pump feeding into your injection pump ?
Yeah, it's hard for me to imagine how even modest injectors would not make a dramatic power improvement to an even slightly modded truck.
Ace
Postby seandonato73 » Sun Oct 25, 2009 6:07 pm
14psi on the fass pump, and i have a stock H1C turbo with an 60mm upgrade compressor wheel and housing...
seandonato73
Postby seandonato73 » Sun Oct 25, 2009 6:13 pm
something that poped to minde after i hit the submit button...i have been having problems with the pump loosing prime overnight...i installed a check valve in line.....but the truck seems to run normal other then it starts hard in the morning
seandonato73
