Build advise
Postby freak007 » Tue Dec 29, 2009 10:09 pm
I do have a line on a turbo I think may work though...
How do these specs look:
S366
Maximum compressor flow - 78 lb/min
Compressor - 66.1 mm inducer, 91.4 mm exducer
Turbine - 79.8 mm inducer, 73.4 mm exducer.
Housing A/R: Compressor: .55, with 4.0" hose-type inlet, and 3.0" hose-type discharge.
Turbine: .91,T4 divided entry, and 4.21" v-band discharge.
It is a non-waste gated housing, price is ~$500
This would be considered a 66/74 correct?? Is this too big??
freak007
Postby soggy » Wed Dec 30, 2009 1:00 am
Too big for your fueling and what you want to do with i would think, plus you would need an exhaust manifold or adapter- our turbo flanges are T3.
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby freak007 » Fri Jan 01, 2010 8:19 am
Well... I have been doing more searching and reading...
I am 90% sure I want a 62/65, but I cannot decide if a 12, or 14 CM housing would be best... Or maybe HTT's 13SS
At any rate, I need to get something going... I want to get these injectors installed 8)
freak007
Postby freak007 » Sun Jan 03, 2010 8:21 am
How well will a Phat Shaft 62 work for me?
freak007
Postby Richie O » Sun Jan 03, 2010 7:36 pm
I would go with a 14 cm. I like a little bigger housing on the exhaust side. 12 cm and high revs = heat. I hear good things of the 62. RSWORDS has one I think.
