dpuckett wrote:I have a Delphi ebay special lift pump- 11-12psi after a fresh filter at idle and cruise. Pulls down to about 9psi on a hard WOT run (near stock truck, though- 25psi boost with my 60/16). Doesnt cost as much as the Cummins pump, flows better than a stock diaphragm pump. It's another option if you dont want to go hog wild with the power. I wouldnt run an electric pump- if I wanted that, I'd get a 2ndGen 24V.
PToombs wrote:1/2 inch suction line to the LPPP, 18 at idle, 14 at WOT. Stock lines and filter after the LP. That's at 347 hp on a mobile dyno. Before the big line it dropped to about 9-10 psi.
91_CUMMINS wrote:How much did the case pump cost n do u know any part numbers?
