Richie O wrote:Not all pumps will run away when the screw is bottomed out. My 89 will, but my 93 will not. You will need to lower the idle some so it will stop.
91_CUMMINS wrote:Will it hurt it if it's bottomed right out or should I back it off a little?
PToombs wrote:Don't force the screw in any farther! There is a shoulder inside that the o-ring on the screw seals on. Mess that up and it will be leaking around the screw and you'll be putting a pump top on it.
Its there, leave it. I had to back mine out 4 full turns when I put in big injectors so mine is no longer maxed out.
91_CUMMINS wrote:Richie O wrote:Not all pumps will run away when the screw is bottomed out. My 89 will, but my 93 will not. You will need to lower the idle some so it will stop.
Remps wrote:The fuel screw can be lengthened to get more adjustment. I just welded a bolt the same OD as the end of the fuel screw, and ground it down smooth. Just be careful to protect the threads on the screw from weld spatter. 3/16" longer is more than enough.
91_CUMMINS wrote:Remps wrote:The fuel screw can be lengthened to get more adjustment. I just welded a bolt the same OD as the end of the fuel screw, and ground it down smooth. Just be careful to protect the threads on the screw from weld spatter. 3/16" longer is more than enough.
It's hitting something tho so how is lengthening it goona help? Just confused a little sry
PToombs wrote:There is a shoulder inside that the o-ring on the screw seals on.
91_CUMMINS wrote:91_CUMMINS wrote:It's hitting something tho so how is lengthening it goona help? Just confused a little sry
I lengthened it wouldn't it just hit sooner?
PToombs wrote:If you don't know how it works maybe you shouldn't be playing with it. Just a suggestion.
