I/P tuning questions close to runaway???
Re: I/P tuning questions close to runaway???
Postby PToombs » Wed Oct 27, 2010 5:31 pm
Don't force the screw in any farther! There is a shoulder inside that the o-ring on the screw seals on. Mess that up and it will be leaking around the screw and you'll be putting a pump top on it.
Postby 91_CUMMINS » Thu Oct 28, 2010 4:58 pm
Richie O wrote:Not all pumps will run away when the screw is bottomed out. My 89 will, but my 93 will not. You will need to lower the idle some so it will stop. :D
Will it hurt it if it's bottomed right out or should I back it off a little?
91 RAM 350, 75HP POD's, HX44, 600HP southbend, ARP head studs, custom intake, 4"exhaust, 3"stainless coolertubz, maxed VE, fuel pin, 3200, snow performance stage 2, boost/pyro guages, 2" lift, 33's/16's, What next?
91_CUMMINS
Postby Richie O » Thu Oct 28, 2010 5:55 pm
91_CUMMINS wrote:Will it hurt it if it's bottomed right out or should I back it off a little?
Its there, leave it. I had to back mine out 4 full turns when I put in big injectors so mine is no longer maxed out.
Postby 91_CUMMINS » Fri Oct 29, 2010 12:03 pm
PToombs wrote:Don't force the screw in any farther! There is a shoulder inside that the o-ring on the screw seals on. Mess that up and it will be leaking around the screw and you'll be putting a pump top on it.
Ok I'll check to see if it's leaking, it's tight but not too tight! Ever sinse tho, it's starts choking at wide open throttle and it's very hard to start now....is that my lift pump going? I just have the stock lp. But my pumps maxed n I hve 75 POd's!
91_CUMMINS
Postby 91_CUMMINS » Fri Oct 29, 2010 12:05 pm
Why did u hve to back it out? I have big injectors too :D
91_CUMMINS
Postby 91_CUMMINS » Fri Oct 29, 2010 12:49 pm
HOw do I get a runaway then? Can u grind the screw down?
91_CUMMINS
Postby Richie O » Fri Oct 29, 2010 2:14 pm
I backed mine out because it was pushing 55 to 60 psi of boost with the new sticks. I wanted to stay around 45. :D My H1C sucks hard core on drive pressure. I bet with a good flowing turbo I would loose 5 to 8 psi of boost.
Postby Remps » Fri Oct 29, 2010 6:47 pm
The fuel screw can be lengthened to get more adjustment. I just welded a bolt the same OD as the end of the fuel screw, and ground it down smooth. Just be careful to protect the threads on the screw from weld spatter. 3/16" longer is more than enough.
Postby 91_CUMMINS » Sat Oct 30, 2010 5:08 pm
Remps wrote:The fuel screw can be lengthened to get more adjustment. I just welded a bolt the same OD as the end of the fuel screw, and ground it down smooth. Just be careful to protect the threads on the screw from weld spatter. 3/16" longer is more than enough.
It's hitting something tho so how is lengthening it goona help? Just confused a little sry
91_CUMMINS
Postby 91_CUMMINS » Sat Oct 30, 2010 5:11 pm
I lengthened it wouldn't it just hit sooner?
91_CUMMINS
Postby PToombs » Sat Oct 30, 2010 5:46 pm
PToombs wrote:There is a shoulder inside that the o-ring on the screw seals on.
91_CUMMINS wrote:
91_CUMMINS wrote:It's hitting something tho so how is lengthening it goona help? Just confused a little sry
If you don't know how it works maybe you shouldn't be playing with it. Just a suggestion.
Postby ahale2772 » Sun Oct 31, 2010 12:30 pm
its not the end of the pin bottoming out its the shank, therefore if u lengthen the end it will be that much longer when u bottom the sucker out, like pete says it bottoms on the oring so be carefull
Postby unixcowboy » Sat Nov 06, 2010 1:42 pm
PToombs wrote:If you don't know how it works maybe you shouldn't be playing with it. Just a suggestion.
That never stopped you Pete....
'93 D250 CC 47RH w/goodies HX-40 60/65/17 w/hx50 flange 55 psi CoolerTubZ 6x16's M2 pin, 4"dp->5" pipe->5" Stack, PS IC
unixcowboy
Postby PToombs » Sat Nov 06, 2010 5:36 pm
Yeah, but I was talking about his truck. ;)
Postby Gots_a_sol » Sat Nov 20, 2010 3:09 pm
Glad to read that this is a known thing, since I just noticed the same thing today while messing with my truck. (turn screw till it bottoms out but could still go more re: not showing any signs of runaway)
-Joe
Gots_a_sol
