Anyone interested in
Re: Anyone interested in
Postby dunes450r » Mon Jan 24, 2011 11:18 am
i'd be up for one depending on price.
as a side question, the 2nd gen pump will work, as long as it has the pressure regulated, or a nifty spring installed to drop pressure?
dunes450r
Postby 1990 » Mon Jan 24, 2011 3:29 pm
Yes.
How is it going to reduce the pressure?
2012 Subaru WRX TP Stage 1 DD
Postby JBradley500 » Mon Jan 24, 2011 4:35 pm
The spring pressure and piston diameter are the 2 factors for psi output.
92 W250- K&N Filter, Smoke Screw Adjusted, Synthetic Transmission Fluid.
340hp/662tq (8/24/12)
JBradley500
Postby truckwrench1 » Mon Jan 24, 2011 5:49 pm
pretty interested any idea on price :D
truckwrench1
Postby IrishChamp » Mon Jan 24, 2011 6:23 pm
What's the price of the high pressure lp and nesessary fittings in it's high pressure form?
1993 W250, 115k miles, pump turned up, M&H Timing Spacer, built a518 w/ steel stator spec rite, he351ve, 16" steel wheels, 255/85r16 BFG Km2's
IrishChamp
Postby JBradley500 » Mon Jan 24, 2011 6:27 pm
they are like 105 shipped from genos garage.
JBradley500
Postby IrishChamp » Mon Jan 24, 2011 6:51 pm
Is anything else required to physically install the pump?
Oregon fuel injection has the low pressure lift pump for under $65 (3936320), these parts could be used to convert a 2nd gen LP to low pressure correct? So if the price of this spring is less than that it would be a great buy right, I'd assume quite a bit less but I don't know ANYTHING about spring manufacturing.
Again, I'm a novice at this stuff but I think a 10 to 12 spi spring would be nice too assuming that 15 is the max advisable for the ve a little breathing room would make me feel good. It would still flow more than any other low pressure LP id assume??
JBradley500 wrote:they are like 105 shipped from genos garage.
IrishChamp
Postby PToombs » Mon Jan 24, 2011 7:25 pm
If you can buy the 6320 pump for $65 grab it! They are discontinued now and the replacement is about $300. If you have that you don't need the 2nd gen pump, spring, or any of that stuff. All you need is the spacer, gaskets, and outlet line, which you need anyways with the 2nd gen pump.
Postby IrishChamp » Mon Jan 24, 2011 7:40 pm
I've not called them to see if the pump is available for $65 still but I think I also remember reading that this one does not put out as much psi's as the one that is now $300.
My thoughts are starting to turn into a little bit of a hijack, sorry, but to get back on topic if the price is reasonable I think a Low Pressure spring for the 2nd gen pump would be awesome!!
PToombs wrote:If you can buy the 6320 pump for $65 grab it! They are discontinued now and the replacement is about $300. If you have that you don't need the 2nd gen pump, spring, or any of that stuff. All you need is the spacer, gaskets, and outlet line, which you need anyways with the 2nd gen pump.
IrishChamp
Postby lectro_static » Mon Jan 24, 2011 11:01 pm
I need to find someone in the Portland, Oregon area with a 1st gen as mine is going to be down for a few months during the conversion. I want to get one spring made and see what the pressure is and tweak it as needed. Any volunteers?
weeping head gasket
4" straight pipe
M&H M3 fuel pin
M&H Dynamic Timing Advance
366 spring
Auto Meter EGT and Boost
lectro_static
Postby dunes450r » Tue Jan 25, 2011 11:58 am
lectro_static wrote:I need to find someone in the Portland, Oregon area with a 1st gen as mine is going to be down for a few months during the conversion. I want to get one spring made and see what the pressure is and tweak it as needed. Any volunteers?
i would volunteer, but i'm in corvallis.....
dunes450r
Postby The_Head » Tue Jan 25, 2011 12:30 pm
81 miles?
The_Head
Postby lectro_static » Tue Jan 25, 2011 1:09 pm
You have a PM
weeping head gasket
4" straight pipe
M&H M3 fuel pin
366 spring
lectro_static
Postby PToombs » Tue Jan 25, 2011 5:51 pm
IrishChamp wrote:I've not called them to see if the pump is available for $65 still but I think I also remember reading that this one does not put out as much psi's as the one that is now $300.
It's the same pump. It's just from a different vendor and they've jacked the price a lot. There are a lot of guys running the 6320 pump, and I've supplied quite a few of them. They carry 15 psi most of the time, with my 370's I can draw it down to about 11psi, which is plenty for the VE to function well.
I'm just saying that there's a lot of screwing around with springs and the 2nd gen pump is more money that that to start with. ;)
Postby ellis93 » Tue Jan 25, 2011 7:03 pm
Hey Mr Toombs can you come up with another one :mrgreen:
