Diesel Power Magazine 1st gen buildup
Postby ford69557ci » Mon Feb 04, 2008 9:28 pm
put that hx35 you took of that 2wd dually and put it on i bet you will be over 300hp when i firt started on my truck i got 325hp out of an hx 35 with a power joke ic
ford69557ci
Postby JQmile » Mon Feb 04, 2008 9:34 pm
ford69557ci wrote:put that hx35 you took of that 2wd dually and put it on i bet you will be over 300hp when i firt started on my truck i got 325hp out of an hx 35 with a power joke ic
Shoot, all I need is 13 more hp! I'm hoping to get that through some dirty cheap tricks and tuning :D Then bottle.
JQmile
Postby ford69557ci » Mon Feb 04, 2008 11:31 pm
13hp wont be hard to do you have the fuel now u just need some simple airflow things.
ford69557ci
Postby 75Dodge » Mon Feb 04, 2008 11:43 pm
One of the biggest restrictions is definitely the the cast intake. Try and find a custom intake or make one. Better yet just try and port and polish the stock one. There ain't much to port but every bit helps!
75Dodge
Postby ford69557ci » Tue Feb 05, 2008 12:02 am
i am still non ic and i built a custom x over pipe out of some 3.5" ic piping from a 24v bus. i also got the 3" intake horn and 3.5" turbo adapter from the same freightliner bus
ford69557ci
Postby DTanklage » Tue Feb 05, 2008 11:53 am
JQmile wrote:
Oh btw, got some new dyno numbers, 287/624. Thing is fueling hard down low now....can't tell ya what we did though, gotta save some stuff for the mag :D
gee, that is hard to figure out - you finally threw that stupid afc lever away!
lol
great numbers, keep up the good work
DTanklage
Postby ford69557ci » Tue Feb 05, 2008 1:06 pm
yes a way better mod than moddin a fuel pin lol
ford69557ci
Postby cummins king » Tue Feb 05, 2008 6:16 pm
ya that was hard to guess :lol:
93 4X4 auto
cummins king
Postby DTanklage » Tue Feb 05, 2008 8:11 pm
or maybe he did the longer bolt thing and has the cone pushed all the way down and THINKS it is really fuelin down low?
lol
tank
DTanklage
Postby cummins king » Tue Feb 05, 2008 8:22 pm
:jumpsmile: ya :lol:
93 4X4 auto
cummins king
Postby JQmile » Thu Feb 07, 2008 10:11 pm
Allright, took it to the track...get ready to not be impressed, as the Hoosiers didn't hook up like I had hoped with my 2wd non-posi. My 60ft time was a 2.35, while the 1/8th mile was 9.6@73mph, which is like a high 14 in the quarter. I aired em down to about 16psi, and my 60ft improved to 2.25, but the rearend started making funny noises and I let off. Still a long way to go, but if I could get the 60ft time down to a 1.9-2.0 like I had hoped, then I could at least run a respectable low 9. Got another 30hp or so up my sleeve with a few tricks, then there is always nitrous......it's a start ;)
On the plus side of things, I cut a perfect .500 light!! First one ever! :shock:
JQmile
Postby flashgordon » Thu Feb 07, 2008 10:49 pm
JQmile wrote:Allright, took it to the track...get ready to not be impressed, as the Hoosiers didn't hook up like I had hoped with my 2wd non-posi. My 60ft time was a 2.35, while the 1/8th mile was 9.6@73mph, which is like a high 14 in the quarter. I aired em down to about 16psi, and my 60ft improved to 2.25, but the rearend started making funny noises and I let off. Still a long way to go, but if I could get the 60ft time down to a 1.9-2.0 like I had hoped, then I could at least run a respectable low 9. Got another 30hp or so up my sleeve with a few tricks, then there is always nitrous......it's a start ;)
The trick with a open diff is trying to get one tire hot enough that your 2nt burn out spins the other tire.........with out pissing off the starter,.......or the guy your racing ;)
You are using True Drag Racing Slick right?(Wrinkle Wall Slicks)
If you have screws in the beed............go down to 12 psi and see how they hook.
Flash
flashgordon
Postby JQmile » Thu Feb 07, 2008 11:08 pm
Naaah not yet. I am using Hoosier Quick times, they're a soft sidewall (not wrinklewall) treaded tire. I'm going to see how I can do with them first, then get some real slicks when I get to 400-500rwhp.
JQmile
Postby ford69557ci » Fri Feb 08, 2008 1:19 am
throw some mt drag radials on there i can hook 1400hp decent with those. weld your spider gears its cheap and solve most traction problems. i run my front and rears welded on the street everyday with no problems and thats with 33 13.50 boggers
ford69557ci
Postby DTanklage » Fri Feb 08, 2008 3:49 am
you dont have to hook hp
you have to hook torque
how much torque does your truck have?
(the one you 'think' has 1400 hp)
DTanklage
