DTanklage wrote:what does that mean in english?
he is doing the same thing i intend on doing ....
building a second , heated fuel tank for wvo ( waste vegetable oil ) , as in the stuff restraunts have to pay to have it taken away .
you filter it down to 5 microns , and fill your heated fuel tank with it .
you start your truck on diesel , and once the oil gets hot enough , so it's around 150 f as it enters the ip , you switch over to veg oil .
bit of a pain to collect and filter the stuff , BUT every day as fuel prices climb higher , it makes it more worthwhile .
veg oil is also a better lubricant than diesel , so i'd be curious how long a 14mm pump head might last on veg oil .....
also the added heat from a 14mm pump head might be benificail to adding more heat to the oil before it hits the injectors .
'93 w250 .... stock ...
