Please tell me wear to start
Postby 93 welding rig » Mon Feb 09, 2009 7:03 pm
hey guys, sorry crazy weekend. ok i checked out goerends website..... little proud of those there torque converters huh? but...... if it helps my problem its worth it. again i hope yall now by now im just stupid when it comes to this stuff, but i need a later model flexplate (what year to what year?) and a good torque converter? and cris that would be awesome but..... what sucks is that truck is how i make my living if im @ work she is with me so down time is very minimal. how long would it take for someone (good) to do these modifications? i have vacation but limited on that all of our family is out of state so most of that is taking kids to see g-ma and g-dad. good news (not that i have doubted yall) one of my good friends seen my ole girl today and said he had the exact same truck in a prior job and she had 330,000 miles on her. also he supported yall in the whole converter upgrade. he said something about a mecedes truck converter worked on his situation???? sound right (dont quote me on mecedes)
93 welding rig
Postby ccoxva » Mon Feb 09, 2009 8:00 pm
Ill help ya just decide exactly what you wanna do. 8) Got a lift and stuff make things alot easier.
1991 N/I 250
1996 Dodge 3500 Ex. Cab Dually 19.5's
ccoxva
Postby SChandler » Tue Feb 10, 2009 12:06 am
93 Welding Rig, if you have the parts ahead of time, you can replace the converter and flexplate in one long day. You will save yourself probably about $300 or $400 in labor. I didn't see if you have a 4x4 or not, but the basic process is this: chock wheels (front and rear), pull driveshaft(s), drain oil from transmission and transfer case (you don't have to drain the transfer case, but you will create a huge mess if you tilt it forward with the oil still in it), unbolt the transfer case (only if you have a 4x4), unbolt the trans. I'm not sure on the exact order, but you will need to disconnect the cooler lines, unhook the shift linkage/cables, unbolt the converter from the trans and the trans from the engine block. Remove the trans, remove the converter, unbolt the flexplate from the crankshaft. With the miles your engine has, it would be a good idea to replace the rear main seal and cam seal while you have the transmission out. Hope this helps. I had to pull the trans in my 92 when the trans went out and it was fairly straight forward (although mine is a manual trans). Get a factory service manual, it will cover all of the steps to remove and replace the convereter.
SChandler
Postby redneckroot » Tue Feb 10, 2009 1:33 pm
Or you can do what one of my buddies did. He rented one of those home depot trucks for like 70 bucks threw his welder on it, went back to the pipe line and picked his truck up at the end of the day from the tranny shop. That poor home depot truck got a work out that day. It got stuck on the line and they had to drag it like 1/2 mile with the dozer back out. He had some pretty funny pictures.
redneckroot
Postby 93 welding rig » Tue Feb 10, 2009 5:14 pm
you are exactly right i have to figure out what i want to do...... thats just it dont know...... i guess just run her till she stops. my grandpa once told me dont fix it if it aint broke. several of the guys said this cause if you invest money in converter and labor. cause i think we all now by now that im dumber than forrest gump on crack when it comes to mechanical stuff, and then you put er all back in then your tranny goes, you get to start all over. guys you dont know how much help you have been. and all the generous offers to help.....is really unbelievable. i will stay in touch and i have got a whole lotta readin to do on this site. chris thanks again for the generous offer and dont go to far cause i may just take you up on it. and please a home depot truck i would love to see those pictures im still laughing..... you no that poor boy caught he!!
93 welding rig
Postby ccoxva » Tue Feb 10, 2009 7:19 pm
You are welcome but if you want me to turn up your pump or something I'll be happy to do it if you bring it up sometime at no charge. :mrgreen:
1991 N/I 250
ccoxva
