Injectors or turbo?
Postby TTipswprd » Fri Aug 21, 2009 1:49 pm
well thanks for the info. lift pump is a little ways out in the futre though. once i get the injectors i will let you know what the egt's are with the pump maxed. do the new era put out alot of smoke or are they clean like ddp's?
TTipswprd
Postby Richie O » Fri Aug 21, 2009 1:58 pm
Postby TTipswprd » Fri Aug 21, 2009 6:07 pm
very nice. im surprised how he only has a little haze out of the truck. min is much worse with smoke now with just the pump up.
TTipswprd
Postby PToombs » Sat Aug 22, 2009 5:44 pm
Wellllll, it's a little worse than those vids show. :roll: I can black out 3 or 4 lanes pretty easy when I want to. ;) The 1st one the tire was spinning and it didn't load the engine much, and pretty much the same for the drag vid. I was trying to take it easy so I didn't blow the tire away, but got right after it once it was rolling.
