Injectors or turbo?
Postby TTipswprd » Fri Aug 21, 2009 1:49 pm
well thanks for the info. lift pump is a little ways out in the futre though. once i get the injectors i will let you know what the egt's are with the pump maxed. do the new era put out alot of smoke or are they clean like ddp's?
1992 w250 4x4, pump tuned, custom exhaust, intake, and dennyT fuel pin, cooler tubz, 5x.014's from SDX
TTipswprd
Postby Richie O » Fri Aug 21, 2009 1:58 pm
Postby TTipswprd » Fri Aug 21, 2009 6:07 pm
very nice. im surprised how he only has a little haze out of the truck. min is much worse with smoke now with just the pump up.
TTipswprd
Postby PToombs » Sat Aug 22, 2009 5:44 pm
Wellllll, it's a little worse than those vids show. :roll: I can black out 3 or 4 lanes pretty easy when I want to. ;) The 1st one the tire was spinning and it didn't load the engine much, and pretty much the same for the drag vid. I was trying to take it easy so I didn't blow the tire away, but got right after it once it was rolling.
