New project race truck
Re: New project race truck
Postby johnelliott52 » Thu Oct 21, 2010 2:45 pm
93 ext-cab auto 3 turns on fuel screw Daily driver
89 "race truck" project 60mm gds, 16cm housing, lots of water meth, drag radials, pump to the head, lowered 3 in, getrag, fuel real close to run away, 3/8ths line from draw straw, holley blue
johnelliott52
Postby ahale2772 » Thu Oct 21, 2010 7:03 pm
dont blow the rag!!!!
Postby JQmile » Thu Oct 21, 2010 8:53 pm
I like your style....throw everything at it, all at once :D Bet it's a blast to drive!
JQmile
Postby johnelliott52 » Fri Oct 22, 2010 2:21 pm
Race ready. Ill post up the results tonight Ill try and get a video and if not I will definetly post a picture of the time slip.
johnelliott52
Postby johnelliott52 » Fri Oct 22, 2010 8:13 pm
Well hit the track and... I feel pretty happy about it. I was running better without the nitrous because my poor stock clutch was slipping horrible, expected though. My best water/meth only pass was a fairly quick 9.4.. So granted shifting gears, slipping clutch, stock injectors, and no nitrous I feel good about it.. love to here yalls input.
johnelliott52
Postby soggy » Fri Oct 22, 2010 8:29 pm
Not too bad, you need to get an auto in there!!
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby lectro_static » Fri Oct 22, 2010 9:07 pm
Get a clutchflight, its a 727 with a clutch instead of a converter, best of both worlds if you can make the tranny hold up
weeping head gasket
4" straight pipe
M&H M3 fuel pin
M&H Dynamic Timing Advance
366 spring
Auto Meter EGT and Boost
lectro_static
Postby oldestof11 » Sat Oct 23, 2010 6:43 am
lectro_static wrote:Get a clutchflight, its a 727 with a clutch instead of a converter, best of both worlds if you can make the tranny hold up
From what I have heard from old farts was Clutchflites were like the Ford 6.0's. You either got a good one or a bad one.
Postby lectro_static » Sat Oct 23, 2010 8:28 am
oldestof11 wrote:From what I have heard from old farts was Clutchflites were like the Ford 6.0's. You either got a good one or a bad one.
They are made by an aftermarket company, link is in this forum somewhere so I would think that the good or bad would depend on who built the transmission and did the clutchflight installation.
weeping head gasket
4" straight pipe
M&H M3 fuel pin
366 spring
lectro_static
Users browsing this forum: No registered users and 62 guests
