Off Road VE Pump
Re: Off Road VE Pump
Postby TheTowingCowboy » Tue May 01, 2012 3:01 pm
AHineman wrote:
TheTowingCowboy wrote:Thus far I have found that nothing ever came from the 4.0 and 4.5 mm Cam plates for VE Pumps. So its a what if kind of thing. And my basic though process would be Off Road VE Pump internals would be naturally bigger then ours cause they would be made to put more power out at a constant non variable speed. AKA More power at one constant RPM. That being said it would be used as part for a 'Automotive' VE pump. So we would keep out gov, just use the internal parts, if they are bigger and better. That was the whole point.
I think Dodge got the highest horsepower stuff besides the marine apps. You can make PLENTY of power with the automotive pump. I'd be more concerned with gathering all the other parts you need to make the build complete. If your current pump is in good working condition and not leaking, a gov. spring and attitude adjustment is all it needs.
With my appetite for Horses and SLED PULLING I need bigger and badder and numbers laying down amazingness. Yes you can make a ton for a VE 620HP or so, but I dont know of many 600 HP Pullers that do well in my neck of the woods. Levi was a big help in explaining a lot of it to me. But I want to be able to hook and go. Though my truck wont be a DD per say it will get driven on the street a bunch. So I want allt he power I can get from a VE pump or swap to a P7100, which looks like a good option.
TheTowingCowboy
Postby AHineman » Tue May 01, 2012 3:14 pm
Might as well p pump it if your want that much power. Cheaper and more reliable in the long run.
Postby TheTowingCowboy » Tue May 01, 2012 4:09 pm
Thats what I figure on running the VE pump while I get all my parts together.
TheTowingCowboy
Postby welderboy250 » Tue May 01, 2012 6:22 pm
I have some cummins direct info on ve equiped 6bta engines rated as high as 192 horse. As far as I know they r 12mm plungers but I don't know which cam, I'm guessing 3.2mm. I currently have a 177hp ve on my truck and I can say it makes a bunch of power but I have yet to verify the cam lift. Maby I can shed more light on this if I ever gat around to it.
1990 W350 5spd. IC'd front end, HX52 on ported 3 piece, full 4" pipe, not as much power as I want but more than enough to break something
Jimmy
welderboy250
Postby oldestof11 » Tue May 01, 2012 6:56 pm
ahale2772 wrote:hence why cummins threw on a P7100 when 94 rolled around.
Nope. I think it was TDR that said Cummins went to that pump because the emissions emitted from the truck at start up (inherent to the design of the VE and its amazing starting capabilities) could not be controlled and pass the test.
Postby ahale2772 » Wed May 02, 2012 7:43 am
hmmm... so they went to a pump that starts like absolute crap...hmmmmm
Postby Tacoclaw » Wed May 02, 2012 8:31 am
Buuuuut, it doesn't start with the governor held at WOT.
I assume anyways, since I refuse to associate with those filthy heathen pumps.
Postby oldestof11 » Wed May 02, 2012 6:47 pm
Tacoclaw wrote:Buuuuut, it doesn't start with the governor held at WOT.
Yes it does. 8)
Picture for reference:
When the governor is at rest like it is now, it pretty much covers up the fuel overflow port. This in turns adds more fuel. You need 400-450 RPM's to get enough weight to move that collar. Go below 500ish rpms, it goes pretty much full fuel.
Postby Tacoclaw » Wed May 02, 2012 7:04 pm
^ That's not a Ppump, is it?
I meant P's don't start at WOT. That's why they start cleaner.
Postby oldestof11 » Wed May 02, 2012 7:24 pm
I got confused... Been a long day!
Users browsing this forum: No registered users and 75 guests
