by flashgordon » Tue Apr 22, 2008 9:32 pm
my GV is older then ACE's and i DO us my exh brake going down hills (4th and over!) with a car and car trailer...........I'm sure there is a sprag in there, but it must be held by a clutch because if it wasn't,........It would simply go into "N" when you decelerate....and it don't.
From the way it was told to me, that's why you can't ingage the GV until 20 MPH, and it automatic disengages below 20 MPH as the pressure is not high enough to hold the clutch, and would cause it to slip.
In "R", it can't inguage do to, too low of speed for it to happen.
I Us it all the time,(GEAR VENDER all the way to the bottom of the mountain.
those that travel I-80 West heading into SLC UT, or I-80 East out of SLC know what mountain I'm talking a about.
Sound to me like its a clutch failure........... GPSMATT, You said that you are engaging it in 4WD..................This could be the cause of the failure as it can't be engaged while your in 4WD..........Unless this GV in mounted between you tranny and T-case, it will brake the GV, make pretzeled drive shaft.......or worse!!!!!!!!
Flash.
