Gear Vendors
Postby mhuppertz » Sun Feb 10, 2008 12:27 pm
DTanklage wrote:send it to my buddy in oregon
jeff marsh - marsh transmission
actually, sent it to his smaller shop closer to his house
hamby trans
tell him tank sent ya
503 885-8852
800 276-5768
Thanks!
I'll give him a call. I would do it myself if I could get parts, but GV is stingy....
i think the first # is hamby trans. if not the 800 # is marsh trans and they will give you hamby trans
jeff is as cool as they come
mhuppertz
Postby DTanklage » Sun Feb 10, 2008 7:26 pm
if you want to do it yourself tell jeff that
i was up there for a drag race and one of the bike guys lost a gear or two in his tow rig (chevy something or another)
jeff helped the guy get his rig and trailer to his shop and let the guy use his tools to pull it that night
the next day jeff had one of his guys go thru it and dude put it back in himself and was on his way back to utah (or somewheres around there)
he will send ya the parts if ya want - i am almost sure of it
don
DTanklage
Postby DTanklage » Sun Feb 10, 2008 7:28 pm
ps - auto trannies are not my deal
if it were me i would have him do it in his clean shop and know nothing got over looked
DTanklage
Postby GPSMatt » Tue Apr 22, 2008 12:07 am
blew up another one so now i havew 2 broken ones lol it doesnt work in reverse i have to put it in 4x to reverse also when decelerating with the gear venders engaged the truck shutters really bad
86 F350 idi
85 F350 crew cab 4x 5.9
95 Lightning
85 GT
GPSMatt
Postby DTanklage » Tue Apr 22, 2008 1:39 am
ummm....you got a broke sprag
a gv is like a lenco transmission
you can not decelerate with it in gear
and you sure as heck are not supposed to back up
sprags are only designed to go one direction
didnt anyone inform you of this???
DTanklage
Postby GPSMatt » Tue Apr 22, 2008 1:57 am
i am well aware that you cant reverse with it engaged. and it shutters with it is not engaged you turn it on it stops.
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby DTanklage » Tue Apr 22, 2008 2:25 am
lol
well, re-read your post
sounded like ya might not have known
sorry for your rough luck with it
maybe call the number i gave ya?
DTanklage
Postby Ace » Tue Apr 22, 2008 5:23 am
DTanklage wrote:...you can not decelerate with it in gear.
Really, how's that? Seems like I'm decelerating when I take my foot off the throttle as I exit the interstate in 5th over. Been doing that for a year and a half now, no problem.
Postby GPSMatt » Tue Apr 22, 2008 8:14 am
DTanklage wrote:lol
yeah thats what i am going to be doing.
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby DTanklage » Tue Apr 22, 2008 10:58 am
if you dont believe me leave it engaged next time you are on the jake brake going down the grape vine
DTanklage
Jake Brake?!
Postby Ace » Tue Apr 22, 2008 11:12 am
I believe using it with an exhaust brake would not be a good idea. The way the clutch applies under tourqe would be pretty hard on it used that way. But letting off the throttle under normal driving up/downhill etc. is no problem.
Postby DTanklage » Tue Apr 22, 2008 3:14 pm
okay then i said it wrong originally
my bad
DTanklage
Postby DTanklage » Tue Apr 22, 2008 3:16 pm
i meant you cant use it to decelerate the vehicle
no down shifting
like with a lenco
DTanklage
Postby Ace » Tue Apr 22, 2008 4:05 pm
I thought they were kinda similar to like one Lenco.
Postby flashgordon » Tue Apr 22, 2008 9:32 pm
my GV is older then ACE's and i DO us my exh brake going down hills (4th and over!) with a car and car trailer...........I'm sure there is a sprag in there, but it must be held by a clutch because if it wasn't,........It would simply go into "N" when you decelerate....and it don't.
From the way it was told to me, that's why you can't ingage the GV until 20 MPH, and it automatic disengages below 20 MPH as the pressure is not high enough to hold the clutch, and would cause it to slip.
In "R", it can't inguage do to, too low of speed for it to happen.
I Us it all the time,(GEAR VENDER all the way to the bottom of the mountain.
those that travel I-80 West heading into SLC UT, or I-80 East out of SLC know what mountain I'm talking a about.
Sound to me like its a clutch failure........... GPSMATT, You said that you are engaging it in 4WD..................This could be the cause of the failure as it can't be engaged while your in 4WD..........Unless this GV in mounted between you tranny and T-case, it will brake the GV, make pretzeled drive shaft.......or worse!!!!!!!!
Flash.
flashgordon
