Fuel pin discussion
Re: Fuel pin discussion
Postby RCCUMMINS89 » Wed Feb 11, 2015 6:05 pm
Pics sent.... you'll notice in the pictures that the BD pin is actually cut more at zero boost than the M&H 3 pin. However, we plan on changing that part. We went off my buddies truck and used his marks.
Postby BILTIT » Wed Feb 11, 2015 6:11 pm
From Rccummins89:
Derek B.
BILTIT
Postby RCCUMMINS89 » Wed Feb 11, 2015 6:28 pm
BD on the right. Like I said... it too can be improved upon.
Postby AHineman » Wed Feb 11, 2015 7:03 pm
Thanks for the pic. Looks just like the "Old Smokey" pin from back in the day....
http://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/old-smokeys-fuel-pin-31123/
That was back in 2003. Funny how somethings have changed, and some have stayed the same.
Postby ellis93 » Wed Feb 11, 2015 7:09 pm
BC847 wrote:
The ramp is too short for the given fuel-pin stroke. This results in additional fueling at idle, as well as it stopping further fuel enrichment before the end of the fuel-pin
m
BC thank you for sharing this.
Postby RCCUMMINS89 » Wed Feb 11, 2015 7:28 pm
If you look, the old smokey pin is notched in at the bottom
Postby RCCUMMINS89 » Wed Feb 11, 2015 11:16 pm
ellis93 wrote:
m
I think what BC said here is a misleading way of wording it. Not sure if it is intentional or not.
As, once again, AFC has zero affect on SUSTAINED SPEED (non acceleration) fuel/air enrichment. The AFC is nothing more than a throttle input regulator (injection event LENGTH regulator). At a given speed, the engine's lean/rich mixture is 100% controlled by the air flow. Now... the exhaust lean/rich result (smoke,haze, etc..) is also controlled by timing, and the injection event (such as injection pressure, injection event lenght, compression, burn time, etc, etc...)
Postby ellis93 » Thu Feb 12, 2015 8:57 am
