Build plan?
Postby PToombs » Sun Feb 24, 2008 6:00 pm
Sure you can. You just have to get the low pressure one. I got mine new, gives 15-16 psi at idle.
Take it apart and measure the bore. Search on here, or ask, there is a thread with pics of the difference.
Postby TWorline » Sun Feb 24, 2008 6:04 pm
Hey Pete I can understand that, seems like there could be some closet perverts around here. :shock:
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby PToombs » Sun Feb 24, 2008 6:12 pm
And some that aren't in the closet! :shock:
Postby GO OVRIT » Sun Feb 24, 2008 7:11 pm
Get the sheep back....that guy makes me nervous. :geek:
GO OVRIT
Postby DTanklage » Sun Feb 24, 2008 7:59 pm
PToombs wrote:
Sure you can.
not without taking it apart and putting first gen parts in it
i shoulda said
DTanklage
Postby ryan10 » Mon Feb 25, 2008 4:12 am
Ok, thanks guys. I know about the regulator. How do i run a big line return line? i just want it to be big lines to the regulator. I dont wanna go all the way to the tank. How should i do it?
1993 w350 6" lift, 35" all terrains. fuel screw in as far as it will go, pump mods, bully dog injectors, bullydog fuel pin, 14cm wastegated housing, water/meth injection. Ground AFC foot, 3200 spring
soon to come: turbo upgrade.
ryan10
Postby ryan10 » Mon Mar 03, 2008 3:42 pm
Ok guys, well the final for now plan is set. I found out that my injectors are a 45 hp injector, and closer to a 190 than PODs, so today i sent out the check for a set of PODs from a member on this site. I also ordered a 2nd gen piston pump. I am going big lines from the piston pump to injector pump and will be running a regulator. i have a hx35 lined up for $150. should i buy it? Goal is for 800 ft lbs.
thanks.
ryan10
Postby ford69557ci » Mon Mar 03, 2008 5:01 pm
hx35 with a 12cm housing will run to hot with pod's
ford69557ci
Postby ryan10 » Mon Mar 03, 2008 5:52 pm
Ok, so it will even be too hot for a play toy? I have water meth, i dont know if that will make enough of a difference in terms of keeping it cool?
thanks
ryan10
Postby DTanklage » Mon Mar 03, 2008 6:00 pm
prolly work great for a toy
DTanklage
Postby DTanklage » Mon Mar 03, 2008 6:01 pm
(if ya do it ALL right)
DTanklage
Postby ryan10 » Mon Mar 03, 2008 6:04 pm
What do you mean by do it all right?
ryan10
Postby DTanklage » Mon Mar 03, 2008 7:31 pm
xxxactly...
DTanklage
Postby ryan10 » Mon Mar 03, 2008 7:40 pm
Ok, not really following you here.......
ryan10
Postby DTanklage » Mon Mar 03, 2008 8:12 pm
you could give two guys the same parts and they could both install them and tune them for their trucks that say still had the stock h1c on them
one guys truck would work great and the other guy would grenade his turbo
DTanklage
