Finally getting the twins going..
Re: Finally getting the twins going..
Postby SNOOT » Sat Apr 24, 2010 11:03 pm
I started at 5 and left at 10 a couple times.
1993 W350
SNOOT
Postby JBradley500 » Sun Apr 25, 2010 7:22 am
are you going to keep running the ddp4's or are bigger injectors coming soon?
(ps- downpipe :D )
92 W250- K&N Filter, Smoke Screw Adjusted, Synthetic Transmission Fluid.
340hp/662tq (8/24/12)
JBradley500
Postby SNOOT » Sun Apr 25, 2010 6:19 pm
JBradley500 wrote:are you going to keep running the ddp4's or are bigger injectors coming soon?
(ps- downpipe :D )
Make a suggestion..
I like how they idle and clean up..
1993 W350
SNOOT
Postby ahale2772 » Thu Apr 29, 2010 6:39 am
snoot, i think the scoops would look cool, if they were infact functional, what are you running for rpm's vs boost i agree with the idea that u need more fuel clearly u have the air side handled :grin:
Postby SNOOT » Thu Apr 29, 2010 7:47 am
The only function they will have for now is providing the engine compartment with cool air. This will help with summer time driving. I have had less heat under the hood with the twins already but when it gets to be 70-80 degrees out its a hole different story.
1993 W350
SNOOT
Postby 1STGENFARMBOY » Thu Apr 29, 2010 7:58 am
That hood is gona be cool, and i agree with every one i think your truck has alot more
HP in it and still be drivable, you should be able to run a low 13 i would think.
Postby SNOOT » Thu Apr 29, 2010 10:47 am
1STGENFARMBOY wrote:That hood is gona be cool, and i agree with every one i think your truck has alot more
Agree on the power lvl. Just learning to drive with twins is quit an adjustment in itself. Twice now I have lifted to fast and blown air into my injectors. Engine shuts off
right now when this happens. One time it happened when I was merging onto the freeway and I had to pull off to the side of the freeway to bleed the injectors. The first time I
was in a little acceleration race with a FURD and let up to fast. I just to the next exit and came to a slow stop on the side of the road.
I was surprized at the following. Last year my best with just my S300 and current fueling I did a best run of 16.48 in the 1/4 mile. This year with a little wind on the back side I ran
a 14.13 with no fueling changes. My pump has lots of turns left in the pump. I know 13's are not going to be a problem at all. I have to start looking for a new drivers jacket already have
a helmet as I need both to run 13.99 or quicker..
1993 W350
SNOOT
Postby Tacoclaw » Thu Apr 29, 2010 12:34 pm
A shutdown after a full-throttle run sounds pretty rough on equipment. Is this a common thing with twins?
Postby SNOOT » Thu Apr 29, 2010 1:42 pm
Its not the lack of fuel that is causing this. When you lift real fast with higher cylinder pressures a small amount of air enters the tip of the injector. This small amount will put the fire out. If I lift slower it will not happen.
The pump itself is not running out of fuel that is a different symptom and will cause the truck to run rough when lifting slowly out of it.
At WOT I still have about 10PSI of the fuel pressure gauge.
1993 W350
SNOOT
Postby SNOOT » Thu Apr 29, 2010 1:44 pm
Tacoclaw wrote:A shutdown after a full-throttle run sounds pretty rough on equipment. Is this a common thing with twins?
To answer your question yes its a common problem weather its a 12V or 24V truck with twins.
1993 W350
SNOOT
Postby Tacoclaw » Thu Apr 29, 2010 2:45 pm
Is there a well-known way to get rid of the pressure? I've got an S400 laying around I hope to use one day, so this is crappy news to me. :/
A micro-switch on the throttle linkage hooked to some sort of solenoid on the intake is one of the easier ways I could see to vent it off. Have it open at idle position and vent it into a filter of some sort. I wonder how much Ford IACs can vent off...
Postby AHineman » Thu Apr 29, 2010 4:51 pm
Blowoff valve?
Postby Tacoclaw » Thu Apr 29, 2010 5:20 pm
AHineman wrote:Blowoff valve?
I haven't really looked into it, but I've yet to figure out how these work on a diesel. On a gasser, the butterfly closing either causes a pressure spike that pops the valve, or a vaccum on the engine side that moves an actuator. On a diesel, there is no vacuum, and I can't see where a pressure spike would happen. Maybe a sudden lack of gasses on the exhaust side from the sudden lack of fuel? Run it off drive pressure, then it would act something like a vacuum-operated BOV and stay open at low exhaust pressure, and close as pressure rises.
Or maybe I'm overthinking this and someone who actually knows will explain it in one sentence. :lol:
Postby AHineman » Thu Apr 29, 2010 6:24 pm
Well, it depends on how much you want spend. :lol:
BD has one for '94 up trucks that uses the TPS. Don't know if it can be adapted to 1st gens with a TPS. Source Automotive sells some that are much simpler (blowoff based on pressure only). The price difference is huge.
Here are some links:
http://www.jegs.com/p/BD-Diesel/BD-Performance-Turbo-Guard-Blow-Off-Valve/761991/10002/-1
http://www.sourceautomotive.biz/shop/products/Blowoff_Valve-117-48.html
But I don't know if one would fix the problem SNOOT is having. :?
Postby swank » Thu Apr 29, 2010 6:49 pm
SNOOT wrote:Twice now I have lifted to fast and blown air into my injectors. Engine shuts off
First time that happened to me was on the dyno. Just about pooped. Hard run, 1350*, 3400 rpm, to what I thought was a seized engine. This is the first I've heard a description of what happened. I just figured there was too much fuel or something and it put it out. This makes a lot more sense though.
truck
swank
