switchblade turbo
switchblade turbo
Postby Remps » Mon Mar 14, 2011 11:07 pm
Re: switchblade turbo
Postby ciamcoop » Tue Mar 15, 2011 2:16 am
That's pretty cool. Seems like it'd be a lot more reliable than the vgt on the 6.7
'93 W250LE 4x4 club cab, getrag, denny t, 366 spring, 181/210 cam, bored. 020, KDP, 5x.014's, piston pump, 4" tbe, cold air, 255/85/16s, 3.54's one wheeler peeler
ciamcoop
Postby dazedandconfused » Tue Mar 15, 2011 4:48 am
Anybody heard anything else about these?
Postby BILTIT » Tue Mar 15, 2011 5:27 am
Anyone phone about a price?
Derek B.
BILTIT
Postby Remps » Tue Mar 15, 2011 6:25 am
If anyone does phone, ask about lbs/min compressor flow.
Postby PToombs » Tue Mar 15, 2011 6:16 pm
Yeah, how much? I bet it's expensive, as it only comes as a kit, manifold, controller, turbo, etc.
Postby Remps » Wed Mar 16, 2011 7:51 am
Prices start at about 3000 bucks. It has a 4" turbine outlet, and I was told it would support boost levels of 50+ psi and up to 750 hp.(comon rail I'm assuming) Was also told the compressor flows 35 lbs/min. (The baby h1c flows more than that, and it'd take 70+lbs/min to support 750 hp) Anyways, you can buy a bolt on twin kit for that kind of money. ;)
Postby The_Head » Wed Mar 16, 2011 10:48 am
Seems like a gimmick to me, but time will tell.
The_Head
Postby MMeier » Wed Mar 16, 2011 11:15 am
Sounds kinda like a fancy quickspool valve to me ? :?
'93 W250CC, 5 speed, 3.54's, pump tweaks, NV4500 conversion, straight piped, 33's. Also, have '03 3500 QC 4WD dually, 551HP/ 1008 TQ @ MATS '07
MMeier
Postby Remps » Thu Mar 17, 2011 11:11 pm
Got some more info on it: The price is 2700 to 3500 depending on bell and whistles. The system is the turbo with the turbine housing with the vane and delphi actuator, the standalone programmable turbo computer, a cahn unit to let the computer and your laptop communicate. This allows you to log data such as backpressure, boost pressure, throttle position, turbo rpm, egt's, and vane position. You can view all of this in real time on your laptop. For most applications controlling the vane using backpressure data works very well and this sensor is included in the lower price. The 63 mm compressor wheel is rated by Borg Warner at 75 lbs/minute by weight. Supposed to go on sale in a few weeks.
Postby The_Head » Fri Mar 18, 2011 6:37 pm
Remps wrote:Got some more info on it: The price is 2700 to 3500 depending on bell and whistles. The system is the turbo with the turbine housing with the vane and delphi actuator, the standalone programmable turbo computer, a cahn unit to let the computer and your laptop communicate. This allows you to log data such as backpressure, boost pressure, throttle position, turbo rpm, egt's, and vane position. You can view all of this in real time on your laptop. For most applications controlling the vane using backpressure data works very well and this sensor is included in the lower price. The 63 mm compressor wheel is rated by Borg Warner at 75 lbs/minute by weight. Supposed to go on sale in a few weeks.
Whoa. Way too much electronics for a first gen. (j/k)
The_Head
Postby MMeier » Fri Mar 18, 2011 9:52 pm
No sthi, I hear ya ' !! Better have one tuff laptop if its going o ride in a first gen !!!!
MMeier
Postby Remps » Fri Mar 18, 2011 10:10 pm
Ya, but you could tell the Duramax guys that you gots EFI Live. :lol: It should be interesting to see how it makes out in a couple years though. It looks to have the potential to be very versatile for a single turbo. Time will tell I guess.
