by delinquent » Sat Aug 06, 2011 8:28 pm
I'd try to run as much pressure as possible. IMO anything less than 75-80 psi is inadequate. Also, these engines can use alot of water. I have a test bottle set up to check flow and check for good atomization. It's nothing more than an industiral plastic container (see through) with a valve stem and a boss to thread your nozzles in. Thread your desired nozzle/jet in, pressureize the system with the valve stem, I normally go to 40-50lb, and then kick the system on. This gives more of a real life look into flow and atomization.
