New Fleece Standalone Controller for HE351VE
Postby AHineman » Wed Oct 05, 2011 6:18 pm
I know a lot of people have come up with other setups, but I thought this was pretty cool.
http://www.competitiondiesel.com/forums/showthread.php?p=1581751#post1581751
Re: New Fleece Standalone Controller for HE351VE
Postby Hansen01 » Wed Oct 05, 2011 6:23 pm
thats awsome :D if only i had $600 to spend on a controller :(
Under construction...
Hansen01
Postby CumminsPower59 » Wed Oct 05, 2011 7:00 pm
It's about time!!! That is now #1 on my want/need list :mrgreen:
Postby Hansen01 » Wed Oct 05, 2011 9:20 pm
think i might weight a couple years for it to go down,lol
but then again by then im sure theyl have something even better out :roll:
Hansen01
Postby delinquent » Wed Oct 05, 2011 10:26 pm
seriously, won't bash anybody but, paying $650 for $30 worth of electronics. Hey, somebody's got to make money. If they didn't patent them, the price will drop quick.
delinquent
Postby AHineman » Thu Oct 06, 2011 7:09 am
IDK, but I think if it was something really easy to come up with, someone would have brought one out earlier. Maybe no one else thought there was really a market for it. If I wanted to build a sweet tow pig, I'd have one. I think it will work with the bigger Holset variable turbos too, so that might open some doors for people.
Postby ahale2772 » Thu Oct 06, 2011 9:40 am
anyone ever see people mechanically actuating them? i just did a bit of a search and came up empty.
I agree 600$ is a bit much for 30$ worth of controler. no offence to them I'm sure they put tons of work into it and if it was one for the later trucks that picks up rpm and all that, then very cool.
but its almost unnessesary to use electronics to regulate the vanes just fron MAP readings IMO....?
but I guess they are adjusting the turbo map and it must be more than just a 1:1 type MAP/vane relationship
wouldnt going off of drive pressure be a better way of doing it? high drive pressure open the vanes, low drive pressure close them... simple....
just dreaming...
Postby 1arock » Thu Oct 06, 2011 1:41 pm
I agree on the costs and thought the same thing in the drive pressure being used to open the vanes. I read somewhere it was done, it looked simple, but I can't find it now.
92W250 w/a 68D100 skin,tach, pyro, boost, trans temp guages, rebuilt a518 w/a PTC converter, 4in muffeled exhaust, 3200 gov spring, he351cw,M@H dynamic timing, 5x12s,M@H M3 pin, pump jacked with, 3.54s, 6+ lift, 14.5x36r rubber,nearly done,"What was I thinking?"
1arock
Postby ahale2772 » Fri Oct 07, 2011 4:34 am
Im thinking the drive pressure might be a bit more accurate/ responsive
...but who knows.
hard part would be getting some kind of diagphram that would not get burnt up from pre-turbo exhaust gasses
Postby Hansen01 » Wed Oct 12, 2011 8:13 pm
This is our Holset HE Series VGT turbo controller for Cummins equipped vehicles 98.5 - 2005. This module must be connected to the 3 pin datalink on the aforementioned years to function.
that is what there website says so would still have to do something about the wiring :?
Hansen01
Postby Gots_a_sol » Wed Oct 12, 2011 8:19 pm
this is a new system that is not vehicle specific according to the comp-d thread.
-Joe
Gots_a_sol
Postby Hansen01 » Wed Oct 12, 2011 8:22 pm
ahh ok guess i skipped that when i read it a couple days ago :roll: :D
Hansen01
Users browsing this forum: No registered users and 76 guests
