Daily Driver Power/Reliability
Postby lowrollin70gmc » Sat Oct 08, 2011 3:33 am
To start, I've been reading articles and posts on this website for a good bit now, but as I'm currently deployed I can't get super in depth searches before time is up on a computer.
Starting with:
91.5 12V intercooled, all stock. Backed w/ Getrag 360, but planning on switch to G56 in a year or two. Motor is in W250 right now, but being put into a 68 K20 Suburban when I get back to the states.
What I want: Obviously more power, but coupled with reliability and no annoying amount of smoke. A little is okay when jumping on it, but I'm not some 13 year old trying to smoke everything in site. Hopefully 300hp/600ft*lbs of streetable daily driver (including winter in NoDak).
What I have access to for cheap: S300G 62/64/13 w/ T3 Flange and 4" PacBrake combo.
Plans: Above turbo 62/64/13
BHAF
3.5" down pipe
4" exhaust exiting behind passenger rear tire
7x.010 injectors (CPP rings a bell)
Denny T stage 1 fuel pin (from memory, could be a different actual name)
3200 Spring
60# exhaust springs, but have also seen some that are beehive and 160#? Pro/cons of each
Stock 1st gen intercooler, or 99-03 Ford 7.3 w/ aluminum ends if it fits in the 68 K20.
Any advice on if this is a good route and changes I should make to the plans?
Thanks,
lowrollin70gmc
Re: Daily Driver Power/Reliability
Postby JQmile » Mon Oct 10, 2011 11:13 pm
Looks good. I made 301 with a set of DDP4's, a compressor upgrade, and intake, and exhaust, so you should be right on track for 300, or even more.
JQmile
Postby cmann250 » Tue Oct 11, 2011 5:13 am
First of all, thank you for your service
Secondly, your plan should put you not only at ~300hp, but a reliable 300ish hp
Users browsing this forum: No registered users and 71 guests
