Which injectors with marine style pistons?
Postby mike8061 » Fri Nov 04, 2011 9:30 am
Since im beduilding my rotating assemble as the start of my build I was wondering, if i put in marine style pisions would i then be better to use 2nd gen nozzels? which has the better angle for the marine pistions?
http://www.cumminsperformanceparts.com/ ... eenre.html
Would there be a benifit to switching to this style of pistion. Im thinking maily of the readily avaible nozzles for 2nd gens. If i remember right they will fit in first gen injectors just the spray angle is diferent?
92/93 W250 Ext. Cab. LP lift pump, 3200 spring, fuel screw maxed, pin almost ground through, 6" lift, flat bed, 35x12.5, big bumper
93 ext cab parted
92 reg cab parted
1967 C50 swapping in spare 5.9 auto and 205. 8.10 low in rearend. should pull somthin
mike8061
Re: Which injectors with marine style pistons?
Postby KTA » Sat Nov 05, 2011 6:19 am
The marine pistons use the wider 155deg spray angle.
Postby delinquent » Sat Nov 05, 2011 2:39 pm
Can you not use the 145* tips? I thought this was a common thing so that the timing could be advanced past 26* without leaving the bowl.
delinquent
Postby oldestof11 » Sat Nov 05, 2011 7:12 pm
Correct. High HP build with lots of timing like the industrial/marine/Non-IC'd pistons to help keep the spray in the bowl.
OP, 2nd Gens have the same angle as 1st Gen IC engines. The only difference is the injector bodies. Nozzles interchange.
