BC847 wrote:Here's where we connect the new big line to the lift-pump.
I made the connection with the typical AN6 90* ELL connector. It is connected to the pump with a AN6 to 1/4" MPT adapter. ~
- Coming out of the lift-pump sorta stumped me as it seems to have an inverted flare fitting. I couldn't find an adapter that would convert it directly to an AN6 line. I run the piston type lift-pump. Its output tube is shaped different from the diaphragm type lift pump. Either way, if you convert the tubing to AN as I did, you'll need to cut the pipe just after it turns away from the block. Here again, I couldn't find an AN adapter that would fit the stupid pipe. I think it's metric. The AN converter I did get fits a 3/8" pipe. I ended up slipping a short piece of 3/8" OD copper tube over the end of the steel pump output tube and braised it sealed. That allowed me to use a regular 3/8" pipe to AN6 adapter. From there the big line ran to the fuel filter with an AN6 90* ELL via a AN6 x 12mm 1.5 adapter.
- Finally connect the fuel filter to the injection pump with an AN6 90* ELL and AN6 Straight connector and two more AN6 x 12mm 1.5 adapters. ~
Users browsing this forum: No registered users and 74 guests
