im done spending money... for a while
Postby jacobwebb57 » Mon Jan 23, 2012 6:08 pm
im done spending money for a while.. im gonna save up for body work, but im not doing that till spring so i need something to do.. im the type that always has to be tinkering with something, so i was wondering what kind of cheep to free mods i can do that may or may not make a difference but are worth trying.. any ideas? thanks in advance
91.5 4x4 5 speed, dennyt stage 2. ddp 50 horse injectors. glow shift boost, fuel pressure, egt, autometer tach, 60lb vavle spring, 3800 gov springs, 1 ton axles, custom intake, 4'' exaust, hx35w pump turned up 3 turns raptor pump, and 1/8 timing.. new injectors sooner or later
jacobwebb57
Re: im done spending money... for a while
Postby JustinRhodes » Mon Jan 23, 2012 6:41 pm
jacobwebb57 wrote:im done spending money for a while.. im gonna save up for body work, but im not doing that till spring so i need something to do.. im the type that always has to be tinkering with something, so i was wondering what kind of cheep to free mods i can do that may or may not make a difference but are worth trying.. any ideas? thanks in advance
This is exactly what i should be doing, quitting the mods and saving up for body work.. but you know how that goes. It seems like you got all the free mods, maybe tune your afc and mess with your timing.
JustinRhodes
Postby 93flatbed » Mon Jan 23, 2012 6:47 pm
Polish everything you can remove and put back on in the same day. Clean up all of the loose ends of wires, put wiring loom over all the old burnt up stuff that came from the factory. Clean out your Hvac box. Clean and paint the little things that will make a big difference once you get your paint and body work done. No point in having a really nice truck until you pop the hood at the local show and shine!
93flatbed
Postby jacobwebb57 » Tue Jan 24, 2012 2:06 pm
thatks kinda what i was planing on
jacobwebb57
Postby ahale2772 » Tue Jan 24, 2012 3:12 pm
Pull you injection pump off, replace the shaft seal, clean up the tappet cover while your there, maybe replace the gasket.
cheep $ to clean the whole left side of the motor, and replace the seal with loctight so your not worried about it popping out
Postby jacobwebb57 » Tue Jan 24, 2012 3:35 pm
what all would replacing the seal involve
jacobwebb57
Postby ahale2772 » Tue Jan 24, 2012 4:31 pm
you need to remove the IP...
pull throttle bracket off, with assorted cables and wiring going to the IP
pull pump mounting bracket of the bottom,
pull all injector lines
pull return line, inlet line
pull AFC line to top of pump
Lock the IP "jam" bolt that locks the IP shaft
CAREFULLY remove IP gear, nut and lock washer, let the gear just sit in the case, making sure not to rotate it (OR THE ENGINE) while you have the pump off
remove the 3 pump mounting bolts, and just pull it off
then just remove the seal with a small screw driver... you kind of have to destroy it to get it off.. but there it nothing behind it that you can damage, so just go at it with a small screw driver
sounds complicated... but its easy... just remove stuff, and put stuff back on. i can pull one off, replce it and have it running in about 3 hrs now
Postby jacobwebb57 » Tue Jan 24, 2012 4:41 pm
ok thanks.. i think im gonna get soem head lights then i might mess around with it
jacobwebb57
Postby Tacoclaw » Tue Jan 24, 2012 6:11 pm
93flatbed wrote:Clean up all of the loose ends of wires, put wiring loom over all the old burnt up stuff that came from the factory.
This is definitely something I would look into. Nothing worse than laying all over your clean truck to get to some wire in the middle of the firewall. Look into putting relays on all the heavy electrical loads and cleaning up/covering the wiring. Try to get a handle on what operates what in the electrical system so something simple doesn't end up parking your truck for a week while you try to figure it out.
Postby jacobwebb57 » Tue Jan 24, 2012 7:18 pm
speeking of something simple...i was cleanign up some wireing under my dash and was putting it back together adn i saw a spark. every thing works except my radio both fuses are good and they ground is still hooked up..any ides?
jacobwebb57
Postby Tsbourne09 » Tue Jan 24, 2012 7:31 pm
Fusible link? Check duckbill?
Not On Yet: 60#VS
Tsbourne09
Postby jacobwebb57 » Wed Jan 25, 2012 5:37 pm
i hate to sound dumb but what is the duck bill
jacobwebb57
Postby ahale2772 » Wed Jan 25, 2012 8:17 pm
^ I know not the answer either
Postby Tacoclaw » Wed Jan 25, 2012 8:22 pm
The rubber thing all the fusible links branch out of.
Postby ellis93 » Wed Jan 25, 2012 8:32 pm
:lol: I've wondered what its proper name was.
Users browsing this forum: No registered users and 77 guests
