Need Help on non intercooled injectors
Postby 91bluecummins » Sun Feb 26, 2012 7:47 pm
Im thinking about putting injectors in my 90 (project truck) and a 60mm compressor upgrade. What is the best size injector to get 5 hole, 6 hole or what .To get a good boost in power and not grenade the turbo. And what is a good brand that are not to expensive sdx, ddp,so no. i was thinking about a 5x.014 sac but what do y'all think. I appreciate it
92 cummins W250 extenged cab (The Goat) project truck
90 cummins W350 single cab dually flat bed 5 speed, he351ve 62mm
1959 chevy Apache 4bt cummins 4 speed
91bluecummins
Re: Need Help on non intercooled injectors
Postby CumminsPower59 » Sun Feb 26, 2012 8:06 pm
Stock N/IC sticks are pretty decent size and good amount of power can be had with them. IIRC they are 4x13's.
5x14's are pretty big, you'll need more air than a 60mm compressor upgrade to cool them ;)
Postby ellis93 » Sun Feb 26, 2012 8:18 pm
Check out JKidd's injectors on diesel auto power. He's got pretty good prices on them. I've also done some searching on them and I've found very little saying problems with them.
Users browsing this forum: No registered users and 57 guests
