wastegate actuator
wastegate actuator
Postby jacobwebb57 » Wed Feb 29, 2012 7:08 pm
i need a wastegate actuator i want something that will go to about 35 to 40..i have stock head studs so it cant be to high
91.5 4x4 5 speed, dennyt stage 2. ddp 50 horse injectors. glow shift boost, fuel pressure, egt, autometer tach, 60lb vavle spring, 3800 gov springs, 1 ton axles, custom intake, 4'' exaust, hx35w pump turned up 3 turns raptor pump, and 1/8 timing.. new injectors sooner or later
jacobwebb57
Re: wastegate actuator
Postby delinquent » Wed Feb 29, 2012 10:19 pm
Don't know if its what you want, but I have a banks big head actuator on a 14cm housing I might separate.
delinquent
Postby jacobwebb57 » Thu Mar 01, 2012 2:37 pm
what would you sugest
jacobwebb57
Postby Tacoclaw » Thu Mar 01, 2012 3:00 pm
Does the wastegate on your HX have a threaded rod on it?
If so, and you have access to an air compressor and regulator, just take your actuator off your turbo, hook the regulator to your actuator and set the air pressure at 35psi. Then, mark how much rod is extending out of the actuator and when you reinstall it you need to shorten the rod until your mark is showing when it's mounted.
That's how I set mine on my S300, though I don't know if yours will have enough travel afterwards to let the flapper open all the way up. you'll just have to try it and see. :grin:
Postby delinquent » Thu Mar 01, 2012 3:14 pm
One thing to think about is that even though you may have an actuator set to open up at 35lb., the drive pressure acting on the wastegate puck will play a large contibutor to when it opens.
delinquent
Postby Tacoclaw » Thu Mar 01, 2012 3:34 pm
That's actually a pretty good point. Have you tried just blocking off the wastegate hose? My S300 gated of right at 40psi without the hose hooked up. Just make sure you plug it so it's not a boost leak.
Postby jacobwebb57 » Thu Mar 01, 2012 7:18 pm
my wast gate is broke the threaded rod broke..
jacobwebb57
Postby delinquent » Thu Mar 01, 2012 7:27 pm
I might have an extra, I'll have to check.
delinquent
Postby jacobwebb57 » Fri Mar 02, 2012 2:34 pm
let me know i would be interested
jacobwebb57
Users browsing this forum: No registered users and 67 guests
