oversized ip lines
oversized ip lines
Postby skilletky » Sat Apr 07, 2012 9:11 am
are over sized fuel lines worth a hoot on our trucks? i remember reading on here about them but cant remember if it was good or bad. i searched and could not bring anything up.
http://www.puredieselpower.com/catalog/ ... 25592.html
skilletky
Re: oversized ip lines
Postby AHineman » Sat Apr 07, 2012 6:30 pm
Always heard they're a total waste of money. But I've never tried them so...
Postby peobryant » Mon Apr 09, 2012 5:06 pm
AHineman wrote:Always heard they're a total waste of money. But I've never tried them so...
Yep, same here. From what I've read from the guys that have done it, they've said it was a waste of money on a VE truck. I haven't personally done it so I can't say for sure.
Postby BC847 » Mon Apr 09, 2012 7:24 pm
Our VE's don't move enough fuel volume for the stock/OEM lines to present as a restriction worth noting.
Further, the larger line ID combined with the fluid's compressibility (albeit both subtle), contribute to an altered injection event timing.
Postby fatty » Mon Apr 09, 2012 9:46 pm
I dunno... There was a guy a couple years back that did a 13.3 at 99 on fuel only with a set of .084 lines.
Postby cougar » Sun Apr 15, 2012 8:06 am
BC847 wrote:Our VE's don't move enough fuel volume for the stock/OEM lines to present as a restriction worth noting.
Just thinking out loud here, but would it make a difference if you had a 14mm head? I know it would be pointless on a stock VE.
01 2500 "the work truck".
cougar
Postby welderboy250 » Sun Apr 15, 2012 8:34 am
To me the real question is how big of an injector tip and what else needs done to the injector before it will flow enough that the line would be a restriction?
But that is just me
welderboy250
Postby Dieselwrencher » Wed Apr 18, 2012 3:38 pm
fatty wrote:I dunno... There was a guy a couple years back that did a 13.3 at 99 on fuel only with a set of .084 lines.
That's not really enough info to back up the claim of saying the larger lines made a difference. Did the IP have modified DV's, did the injectors still have edge filters in them? There are a lot of variables here.
I know a couple guys that had them on stock and 14mm ve trucks and no one was happy after buying them.
2000 Excursion VE 24v 47RH 4x4
1976 Chevy K30 Crew Cab Short box P-pump 12v 47RH
1972 Chavy K30 P-pump 24v 47RH
1968 Corvette 5.9 47RH
Dieselwrencher
