pop pressure
pop pressure
Postby danc » Sun Apr 15, 2012 6:03 pm
Any one tried running lower pop pressure?
1993 club cab 2wd, auto,s300,5x14s,BHAF,powertrax,denny t, Carter 100gph,specrite tc, built 518,tampered pump,and a new headliner.
danc
Re: pop pressure
Postby peobryant » Sun Apr 15, 2012 6:07 pm
What would be the advantages to that?
Re: pop pressure
Postby BC847 » Sun Apr 15, 2012 6:36 pm
peobryant wrote:What would be the advantages to that?
Allows a wee-bit more fuel in a given injection event window. (The injection event window becomes wider). It perhaps comes at the expense of a little slobbering at the start and finish of the event.
I run mine at 235BAR (+/-2.5)
Re: pop pressure
Postby skilletky » Sun Apr 15, 2012 6:55 pm
I think mine are set to 220 or 227 bar. Burn kinda dirty. I need to pull them out and have the NOP bumped up some. It runs pretty damn good how it's set now, but the smoke is kinda crazy
skilletky
Re: pop pressure
Postby danc » Mon Apr 16, 2012 12:01 am
I was thinking it would add more fuel and increase duration w/o having to bump timing. BC did you have any change in smoke or haze or any before and after dyno #s?
danc
