advantage to changing pop pressure
Postby ellis93 » Wed Feb 13, 2013 6:42 am
Is there any advantage to messing with it,as far as fuel mileage or flow from injector?
Besides the 245bar spec,what have you all seen them changed to?
Re: advantage to changing pop pressure
Postby BC847 » Wed Feb 13, 2013 9:22 am
i've been known to have dropped the POP-pressure a little so as to move more fuel. :roll: I don't believe such would do any good with mileage. :?
Postby ellis93 » Wed Feb 13, 2013 5:46 pm
So....moral of the story is set it to 245bar and motor on....okie dokie :lol:
Postby RCCUMMINS89 » Thu Feb 14, 2013 6:45 pm
Depends.....
Setting it a little higher can help with the spray, but can also hurt you on your timing, so it depends how much you go.
Meaning...... I like to run mine at 3650 psi as opposed to 3550.
Postby DodgeFreak » Fri Feb 15, 2013 6:19 am
Setting them higher should help with haze too. Couldn't you make up the timing by advancing the pump? I read someone had injectors bumped up 60bar and his timing dropped from 22* to 15-16* by light..This was on a p-pump though. and i don't remember where i read it lol
Postby dunes450r » Fri Feb 15, 2013 1:19 pm
the higher the pop pressure the more strain you're putting on the pump as well....
dunes450r
Postby RCCUMMINS89 » Fri Feb 15, 2013 1:26 pm
Correct..... can't go wrong with staying at stock pressures.
But injector pop pressure, injector size, how much the pump is turned up, etc..... all have a play in this.
Postby cougar » Mon Feb 18, 2013 9:35 am
PODs are commonly used and as far as I know, they have not caused any pump damage. PODs have a higher pop pressure than stock, that is why they run better with more timing. But then again, hole number and size could make the difference.
01 2500 "the work truck".
cougar
