Grid heater replacement
Postby Makaio » Fri Nov 02, 2007 10:29 pm
Glacier Diesel Power makes a grid heater replacement for 98.5-07 Cummins 5.9's. This will fit a 1st Gen, right? I sure don't need the heater here. ;) Anything below 65* is freezing for a Hawaiian in his boxers. This would be a nice installation for some increased air flow.
Aloha,
Matt
Matt
1992 W250 auto, ASA/AFE intake, H1C hybrid 60-16, Bosch 190's, Bully Dog fuel pin, 366 spring, modified pump and a 4" turbo back exhaust. Suncoast valve body plumbing 3.54's w/LSD. Autometer gauges.
Makaio
Postby rbrettctd » Sat Nov 03, 2007 6:03 am
I believe theirs will work. Personally, I found a used one, pulled the bolts, tapped the holes and plugged em to make my own...
Randy
rbrettctd
What's the Difference?
Postby Ace » Sat Nov 03, 2007 8:17 am
I been working airflow issues recently and am wondering what's the diference between the later/earlier grids? Any pics? Sounds like something that could be picked up at a salvage yard cheap....
Ace
Postby Begle1 » Sat Nov 03, 2007 8:34 am
Couldn't they just be replaced with some hogged out aluminum chunks?
Postby Ace » Sat Nov 03, 2007 9:25 am
Sure, but they wouldn't make very good heaters! :P
Ace
Postby Begle1 » Sat Nov 03, 2007 11:48 am
Ace wrote:Sure, but they wouldn't make very good heaters! :P
Heaters are only for smoke reduction purposes until you get to around 0 degrees, right?
What point do they become necessary for starting?
Postby rbrettctd » Sat Nov 03, 2007 11:51 am
They sure help for starting under 40! I never see temps under 0 here, but Im putting mine back anyways. I sure dont want to strain that new-last-year $120 battery and wear it out any quicker than I have to.
Randy
rbrettctd
Postby Begle1 » Sat Nov 03, 2007 12:32 pm
Does it really require extra cranking under 40? I would think the huge amp draw from the grids would wear out the battery as much as quite a bit of extra cranking?
I really don't know anything about it... I don't know if my truck has started in under-50 degree conditions in the past 18 years...
Cold Starting
Postby Ace » Sat Nov 03, 2007 1:27 pm
They do help cold starting, especially when you get down into the single digits. Mine has always lit right off either way, but it runs smoother with a preheat cycle first. Dead cold at zero degrees and no preheat, it will start just fine, but stumble and run a little rough for the first half minute or so, until they've cycled once.
Ace
Postby gomerpile » Sat Nov 03, 2007 2:56 pm
well say im in a machining class at school, would it work to get an oversized piece of aluminum and hollow it out to fit on the intake, and then make the out side of it finned to allow a little bit more of a temp drop., just let it work like a heat sink, you know just incase every cfm/temp drop is required. and do yall think this would help with fuel economy. and would it be cheaper if i have access to tools, to make it myself compared to $70 at g/diesel?
1992 Dodge D-250 LE auto, LSD w/3.54, about 200,000+ miles.Isspro Pyrometer , Sunpro tach,Tractor Supply Boost Gauge, Old Smokey Fuel Pin,4 turns on fun srew, starwheel turn CCW 1 turn, 40hp injectors, BHAF,16 cm housing.Sony Head Unit.
gomerpile
I doubt it
Postby Ace » Sat Nov 03, 2007 3:01 pm
You'd get better flow without the grids like Beagle says, but cooling's not really going to be an issue. There's not enough surface area and the air's not in there long enough to transfer much heat.
The grids are able to pre-heat starting air for just the opposite reasons.
Ace
Postby cummins king » Sat Nov 03, 2007 3:21 pm
http://cgi.ebay.com/ebaymotors/ws/eBayI ... =p3907.m32
you can get them here, they are made for 88 to 93, and they look cool
93 4X4 auto
cummins king
Looks Like No Heater Grids
Postby Ace » Sat Nov 03, 2007 3:25 pm
So back to the OP. Looks like this is not a "Heater Grid Replacement," but a larger, empty heater grid housing/spacer.
Ace
Postby cummins king » Sat Nov 03, 2007 3:28 pm
kind of usless replasing it because if you got 40 pounds of bost before the heater ur going to have 40 pounds after, and your going to have the same admount of flow
93 4X4 auto
cummins king
Postby Ace » Sat Nov 03, 2007 4:05 pm
I was possibly interested in something that might be a better/more efficient heater! :cry:
Ace
