Ace wrote:That thing is a pretty beefy planetary gearset. I have no doubt it stands up well to whatever it gets bolted to, Cummins included.
OTOH, the oil capacity for the large sump is only a bit more than one and a half quarts. Smallish, by my standards. And they recently started spec'ing Syntorq and the GM equivaleny part# as the preferred lubricant for some reason. I'd be willing to bet most of the GV failures we've heard about can be traced to lube-related root cause. Either not changing the fluid often enough, or using the wrong gear oil.
DTanklage wrote:what fluid you put in them definitely determines how hard they will shift
i remember 20 years ago GV recommended atv - if ya can believe that
then, I think they started rec motor oil
I don’t know, I will run anything in mine
I don’t remember what I put in mine when i first installed it but man, it shifted way too hard
made it a nightmare to drive
now I just use the stalube 90 wt (syn)
this unit is about 2 yrs old and has been thru hell
when you are on it at 3 grand, maybe 3200, in 4th gear and you pull the red lever - watch out
whole fregin truck jumps
I mean it pulls hard
if you are racing someone that is basically as quick as you that one shift is good for 2 truck lengths
and those two lengths happen almost instantly
I have a friend in oregon that rebuilds them really well, and for a good price if interested
don
