Ace wrote:That thing is a pretty beefy planetary gearset. I have no doubt it stands up well to whatever it gets bolted to, Cummins included.
OTOH, the oil capacity for the large sump is only a bit more than one and a half quarts. Smallish, by my standards. And they recently started spec'ing Syntorq and the GM equivaleny part# as the preferred lubricant for some reason. I'd be willing to bet most of the GV failures we've heard about can be traced to lube-related root cause. Either not changing the fluid often enough, or using the wrong gear oil.
DTanklage wrote:what fluid you put in them definitely determines how hard they will shift
i remember 20 years ago GV recommended atv - if ya can believe that
then, I think they started rec motor oil
I don’t know, I will run anything in mine
I don’t remember what I put in mine when i first installed it but man, it shifted way too hard
made it a nightmare to drive
now I just use the stalube 90 wt (syn)
this unit is about 2 yrs old and has been thru hell
when you are on it at 3 grand, maybe 3200, in 4th gear and you pull the red lever - watch out
whole fregin truck jumps
I mean it pulls hard
if you are racing someone that is basically as quick as you that one shift is good for 2 truck lengths
and those two lengths happen almost instantly
I have a friend in oregon that rebuilds them really well, and for a good price if interested
don
I look into the mirror expecting to see part and pieces shelling out from under the truck................no parts, let the clutch out again, step on the gas all good. Users browsing this forum: No registered users and 37 guests
