Do I have a set of NON IC'ed DVs?
Postby BC847 » Sun Oct 06, 2013 6:34 pm
Stock/OEM IC'ed DVs on the top, Those I'm wondering about on the bottom . . . .
Stock/OEM IC'ed DV plunger on the right. On the left, those I'm wondering about.
The thing that's throwing me is the "Retraction-Piston" on the plunger of those I'm thinking are NON IC'ed DVs. (That Retraction-Piston is what the P-pump crowd have lazer-cut and such).
Can anyone with Sho'nuf NON IC'ed DVs confirm what I have?
Re: Do I have a set of NON IC'ed DVs?
Postby ellis93 » Sun Oct 06, 2013 7:54 pm
I have a non molested non i/c pump on the floor at the shop..... I'll take out a valve
Postby BC847 » Sun Oct 06, 2013 8:05 pm
Thank you, Sir. :)
Postby ellis93 » Mon Oct 07, 2013 5:39 am
Looks like it ;)
Postby CumminsPower59 » Mon Oct 07, 2013 6:06 am
Here is the thing I have noticed in the last few pictures...the Non-IC DV's in BC's pics have a ridge between the "flutes" and the 45deg. cut on them. The one Ellis posted, doesn't.
Postby RCCUMMINS89 » Mon Oct 07, 2013 10:28 am
Yep.........different.
BC.....cut 'em up.
Postby BC847 » Mon Oct 07, 2013 1:26 pm
Thanks guys. 8)
I may end up swapping the full-cut plungers and seats of the IC'ed DVs, . . . into those longer bodies. :scratch:
Postby ellis93 » Mon Oct 07, 2013 2:21 pm
That delivery valve was pulled from a non intercooled pump,I'm on the wrong page with you fellers or something..... :scratch:
Is the one with the extra land i/c or non i/c? :/
Postby BC847 » Mon Oct 07, 2013 2:49 pm
ellis93 wrote:That delivery valve was pulled from a non intercooled pump
That's what I needed to see. I apparently do NOT have NON IC'ed DVs.
ellis93 wrote:Is the one with the extra land i/c or non i/c? :/
Neither. Perhaps for a different application (other than the Dodge/Cummins setups).
Again, thanks. 8)
Postby RCCUMMINS89 » Mon Oct 07, 2013 3:45 pm
Wonder if that is where your missing fuel is
Postby BC847 » Mon Oct 07, 2013 4:25 pm
RCCUMMINS89 wrote:Wonder if that is where your missing fuel is
Quite possibly.
I've most recently come to the realization that my driving the AFC with that from the primary turbo may also be contributing to . . . the delay in the ramping-up of power when one launches with 25psi . . . . up to full boost. The first 60ish feet if you will. The other side of that coin is that it helps clean up no, to low boost smoke.
Crap. :shaking:
Postby ellis93 » Mon Oct 07, 2013 5:30 pm
Yeah finding extra fuel is gonna screw your whole world up ain't it :)
I wonder what's breaking next in the trans :(
Side note,I'm in the process of detuning mine,I've tired of it all. Back to pulling power...... :roll:
Postby BC847 » Mon Oct 07, 2013 6:47 pm
ellis93 wrote:Yeah finding extra fuel is gonna screw your whole world up ain't it :)
The voices have a pool going, talking about the rear-end. :shock:
Postby RCCUMMINS89 » Mon Oct 07, 2013 7:13 pm
Only a matter of time..........That's a decent amount of miles on a Dana 70 (limited slip I assume) taking that much brunt.
Postby PToombs » Tue Oct 08, 2013 5:59 pm
Yeah, the Voices. I keep hearing them giggling and snickering about my trans. :roll:
FOCK 'EM! :finger: :jumpsmile:
