how does the m&h timing spacer work?
Postby Joecochrane » Thu Jan 16, 2014 1:55 pm
I have a first gen bus motor it does not have a ksb so I was told I can't run the m&h timing spacer is this true?
The driver 02 2500 ho 6 speed 2wd lil lift 35s edge cts hot some injectors and a fass
The toy 87 f350 39.5 tires 180 bus motor 727 trans maxed pump ground pin bumped timing 366 spring hx35 and a lot more in the works.
Joecochrane
Re: how does the m&h timing spacer work?
Postby RCCUMMINS89 » Thu Jan 16, 2014 1:58 pm
No, that is not true. The spacer may go under the ksb, but still works the same.
The timing spacer does 2 things. First, it allows more travel by spacing off the blocking plate (with ksb, or in your case an actual plate) and allowing further travel. Second, it takes some pre load off of the timing spring and thus allowing a faster timing advance.
Postby Joecochrane » Thu Jan 16, 2014 2:36 pm
So it goes between the pump and the engine?
Joecochrane
Postby RCCUMMINS89 » Thu Jan 16, 2014 2:55 pm
It goes underneath your plate, where the ksb usually sits.
Postby jdiesel_us » Thu May 08, 2014 1:12 pm
So is this spacer worth the trouble to install on an otherwise stock engine? Looking at their fuel pin and spacer along with a 3200 gov spring to help wake up my truck.
jdiesel_us
Postby BC847 » Thu May 08, 2014 1:44 pm
jdiesel_us wrote:So is this spacer worth the trouble to install on an otherwise stock engine?
Yes!
IMO, the spacer and the 3200 rpm gov spring are the best basic upgrades one can do to the VE. :cool:
Postby Knoberman » Wed May 14, 2014 6:02 pm
Hey rc, you sell these spacers?
92 Cummins& a 518. installed in a 86 cclb f350 4x4
Knoberman
Postby RCCUMMINS89 » Wed May 14, 2014 6:19 pm
Nope...
Postby matthewh » Wed May 14, 2014 6:21 pm
RCCUMMINS89 wrote:No, that is not true. The spacer may go under the ksb, but still works the same.
Sorry for not knowing more about these pumps, but can you elaborate or explain more about how this spacer works? I'm all for easy upgrades to my truck, just like to know best I can what I'm doing and what the piece accomplishes
matthewh
Postby Diesel » Sat Jun 21, 2014 2:00 pm
TTT how does this work?
1991.5 D250 Intercooled A518
Diesel
Postby Knoberman » Sat Jul 05, 2014 6:36 am
Knoberman
Postby dbshelton » Thu Oct 02, 2014 4:09 am
This is one mod that sounds like it's hard to top. I'll try one some day.
dbshelton
Postby Lunatic76 » Tue Nov 11, 2014 3:55 am
I know it's an old post but I'm glad it was brought back up. I've wondered about it and now I know.
Lunatic76
Postby Diesel » Tue Nov 11, 2014 4:54 pm
dbshelton wrote:This is one mod that sounds like it's hard to top. I'll try one some day.
How so? Does it seem hard to top? It seems like moving the pump toward the head would be the mod that is hard to top.
Diesel
Postby matthewh » Tue Nov 11, 2014 6:51 pm
I'm still wondering how this spacer works, haven't found a great answer yet
matthewh
